Results 1 to 24 of 24
    Active Member Guzzi's Avatar
    Jun 2012
    New Smyrna Beach, Florida
    Default New kenda kanine tires
    Have a new 2020 RTL. 500 miles. Already had dealer replace left front out of round factory Kenda. Ordered a pair of new Kenda KR20 Kanine's, to mount on spare wheels. Factory tires had usual massive balance weights on them. New Kanine's balances with 1/2 oz on left and 3/4 oz on right side. Both perfectly round😁 what a difference!! Rides smooth and straight. Handles great.
    GUZZI :
    2020 RTL blue
    Dec 2013
    Quote Originally Posted by Guzzi View Post
    Have a new 2020 RTL. 500 miles. Already had dealer replace left front out of round factory Kenda. Ordered a pair of new Kenda KR20 Kanine's, to mount on spare wheels. Factory tires had usual massive balance weights on them. New Kanine's balances with 1/2 oz on left and 3/4 oz on right side. Both perfectly round�� what a difference!! Rides smooth and straight. Handles great.
    Well that's gotta be a good start & a fair bit of an improvement from Kenda! Hope it keeps on going that way... Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2017
    Durham,Maine
    I need two this spring, may go that root just to test them out!!
    2012 RTL , Pearl
    Feb 2020
    Ohio
    I just got a 2020 RTL and was wondering which version of Kenda tires it came with. They just say Kenda Radial on them. Should Kanine be on there somewhere if they are the new version?
    Jun 2012
    Yes, the new version says kanine on the sidewalls. Slightly different tread also.
    GUZZI :
    2020 RTL blue
    Feb 2020
    Ohio
    Thanks!
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Flyback View Post
    The 2020 RT I saw had the Kanine's mounted. The dealer didn't even know they were different. So I'm not sure if the Kanine's came on all 2020's. Or if it's just the recent ones that have them. But if the early reports are any indication. I would say BRP finally, after 12 years, has gotten it right. We will have to see how the wear pattern goes.
    Good thing if BRP is now installing Kanines on the new RT's. I am guessing if that is the case, their backup tire inventory has been cleared of the original OEM's...or...maybe installing the new Kanines as a premium add on for their now premium RT.
    This could also be a dicker factor when purchasing a new RTL. A fresh set of Kanines installed.
    Sep 2018
    Sneedville, TN
    I'm glad to see this. I'll be needing tires soon, and I'll feel much better with an improved tire that meets BRPs requirements for compatibility with the Spyder's high tech suspension.
    RC
    2018 Spyder RT Limited
    Asphalt Gray
    Can Am Passenger Armrests
    Can Am Comfort Seat
    Spyder Accessories Floating Footpegs
    Utopia Driver Backrest
    Bajaron Sway Bar
    Sena 20s Bluetooth
    Lidlocks Helmet Holders
    F4 Tall and Wide Tinted Windshield
    Fobo Tire Monitor
    Lamonster Spyderdock Cell Phone Holder
    Sheepskin Seat Cover
    Drink2Go Cup Holders
    Magic Mirror
    Can Am Trailer Hitch
    Missing Belt Guard
    Wish List - LED Headlights and Fog lights
    I don't think anyone has posted that " for special motorcycle use only " is on the new Kanine's ……. Could someone who actually has them clarify this .….. Thanks from all of us Spyder owners …… Mike
    Oct 2013
    Farmington, Delaware
    See post 1 images. It is on the Kanine.
    SpyDel
    2017 F3 Limited
    Feb 2020
    illinois
    was at dealer yesterday and the 2020 RT Limited was next to a 2019 RT Limited. the front view of the front tires were the same tread design....
    Active Member will's Avatar
    Mar 2012
    Harpers Ferry, WV
    This thread got me curious. The following pictures are from my 2020 Spyder RT Limited that I bought in February in VA.
    2020 Limited , Petrol Metallic
    Mar 2012
    Harpers Ferry, WV
    This is the third picture I meant to send, not duplicating the whole tire.
    So no one has to go blind or spend a 1/2 hr. trying to get the answer ….. The New Kanine tire is labeled " for special motorcycle use only " ….which leads me to believe it isn't any stronger than the originals …… because - " f s m u o " is a Warning …… good luck …. Mike
    Nov 2019
    PA
    The image is not that clear, but doesn't the OP's photo 152023 show the word Kanine at about 5'oclock on the sidewall?
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by japgen View Post
    Yes, they do show Kanine, but I’m not sure what point you are making there, japgen. The OP had his dealer change his tyres to Kanines, which he then photographed.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Nov 2019
    PA
    Pete
    So sorry, my mistake. I thought there was some confusion about what tires had been mounted. In re-reading the thread, it's clear.
    Jun 2016
    Hahaha..... We have ALL been there, japgen.......I just thought I might be missing something
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Dec 2017
    New Zealand
    Hi has anyone got a picture of the rear tyre and tread, as this is what I want to replace and make sure they put the right one on. 2011 RT
    2011 RT , Manuctaured my own for aux lights Pearl white
    Nov 2018
    Denver, Colorado
    saw a new 2020 this weekend...It DIDNOT have the new tire on it...just the old one
    Sep 2014
    USA
    See my post on #149 with the pictures that was taken.
    https://www.spyderlovers.com/forums/...ht=kanine+tire
    Sep 2014
    USA
    Quote Originally Posted by JBnLIZ View Post
    See post#22 it takes you to another thread on the subject and has pictures. See post#149
    Nov 2018
    Claremore, Ok.
    The new Kenda tires might be better made than the previous models but the main take-away is that they are still only 2 ply sidewalls that probably require higher psi which might make them a little rougher riding. This is just speculation on my part but I'm extremely happy with my Federal Formosa AZ01s running 17psi.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
