Results 1 to 6 of 6
    Mar 2015
    Brockport, NY
    Default 2020 RT rear tire size
    Is the rear tire the same size as previous years of the rt on the new 2020?
    2014 RT-S Pearl White
    Yes.
    Aug 2012
    Central Coast, CA
    Yep. However, changing a rear for the home DIYer is going to be a bear. The new mudflap is huge and hangs waaay down and will definitely get in the way.
    2020 RTL SE6
    Mar 2015
    Brockport, NY
    I was wondering mainly because I have a brand new ready to install rear tire in my garage. If all goes well, I’m planning to pickup a leftover 2020 at the end of season, so I will definitely hang onto the tire I have.
    Sep 2009
    La Valle, WI
    The mudflap is the same as the F3L. Just lift rear up higher. Mine wasn't in the way at all. You drop wheel straight down and out to the side. Pretty straightforward.
    2018 F3 Limited , Oxford Blue
    Mar 2013
    Quote Originally Posted by JP58 View Post
    Yep that's what I do.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
