Page 3 of 3 FirstFirst 123
Results 51 to 55 of 55
  1. #51
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    I didn't like the"road-runner" beep-beep horn on my Spyder. So I purchased a dual horn set (~$15 at geek dot com). The dual horn set I had purchased claimed to be 300 dB. But anyone familiar with sound knows that claim would be BS and, if accurate, would damage your hearing. But regardless, it is plenty loud. It probably sounds more like the horn on my 2003 Goldwing. Also note that volume is NOT the only goal. A dual horn puts out a more distinctive sound that gets more attention. I believe the horns are 410 Hz and 510 Hz and together gain more attention.
    I also used a FARBIN Horn Wiring Harness Relay Kit I purchased from Amazon for about $10. It simply uses the standard horn wires to activate a relay that feeds the dual horns power through it's own fused line from the battery. This averts the potential for overloading a Spyder horn fuse. I now have adequate horn volume plus an additional audio dimension from the pair of horns.
    The wiring was the easy part. Getting my hands and tools up into the horn area to remove the original horn and fit the new horn set to the bike was more difficult.
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
  2. #52
    Feb 2016
    Lake Wylie South Carolina
    Quote Originally Posted by Spyder2014 View Post
    I am searching for a very LOUD horn for my F3 and RT Limited. I am wanting to mount a air horn with more than 150 decibels. In other words a big car horn or a train horn. Sounds funny but it would get people's attention.
    Anyone know of anything like this?
    I have a motohorn installed. Loud enough for me.
  3. #53
    Active Member FIRECAT's Avatar
    Aug 2010
    WINDSOR,ONT,CAN
    And I went with the Moto horn from lamonster, very easy install very loud, best way to go
    SNOWMOBILING ON PAVEMENT!!!
  4. #54
    Aug 2019
    Stoughton, WI
    2022 RT Sea To Sky
  5. #55
    Active Member Navvet's Avatar
    Apr 2016
    NC
    Motohorn is great !!!
    2013 F6B
    2016 F3 Ltd
    2016 F3 LTD , Triple Black
Tags for this Thread
