Results 1 to 4 of 4
    Active Member J48cruiser's Avatar
    May 2015
    East Northport
    Default HELP NO AM Radio and FM
    I have lost my AM on my radio what is there is LW and MW and on FM the numbers do not match what we have. My Ride is a 2015 RT Limited with factory Xm witch works Fine. the bike has not bin use since November just started it today and had this problem. Any Help would be great.
    BAJARON SWAY BAR PLUS LINKS
    BAJARON SPACER
    ULTIMATE SEAT WITH GAS DOOR
    JT SHELF BAR
    SPYDERFLAP
    BUMPSKID
    XM RADIO
    POWER OUTLET
    LAMONSTER CUP HOLDER
    2015 RT LIMITED
    PIN STRIPPING BY MACK THE KNIFE
    RIVCO FLAG HOLDER
    SENA SM10 BLUE TOOTH
    LAMONSTER FBB HIGHWAY BRACKET WING BOARD BLK
    BPR TRAILER HITCH
    KRADELLOCK FOR THE GPS
    BIG BRAKE PEDAL BY TRICLED
    It sounds like the battery may be low since you mentioned it has been idle since November. When funny electronic stuff happens, that is sometimes a clue.
    Faribault, MN
    Your Radio / Dash may have switched regions since you're seeing other country radio settings. Check your manual Page 35, ,it's in there.
    "Selecting the Region (Audio)
    To select the region:
    Select AUDIO in main category of Preferences Screen.
    Select REGION in secondary category.
    Select the appropriate region according to the table below in main unit or
    setting.
    NOTE: If your country is not listed in
    the table below, select a region with an
    identical frequency range.
    Restart the vehicle in order for changes
    to take effect.
    Should be :A: for North America
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    May 2015
    East Northport
    Thanks for the help it worked like a charm
    BAJARON SPACER
    JT SHELF BAR
    SPYDERFLAP
    BUMPSKID
    XM RADIO
    POWER OUTLET
    2015 RT LIMITED
    RIVCO FLAG HOLDER
    BPR TRAILER HITCH
