Results 1 to 6 of 6
Thread: Torque spec's
    Active Member Gilly's Avatar
    Dec 2019
    Musquash , New Brunswick , CANADA
    Default Torque spec's
    Hi all , looking for the torque spec's on the oil filter cover and the HCM "screws" (2009- se5) Shows in the Operator's guide for the drain plugs (15 lbf.ft), but not the screws . Tried the search bar .. but no luck . Thanks .. Gilly
    2009 Roadster SM5 , Silver and Black
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Florida Swamp
    Torque Specs are for clean, dry threads. It is difficult to get clean, dry threads on anything that contains or contained oil........... specially when the opening points down.
    What Highwayman just said up there.............
    2019 F3-S , Black & Silver
    Oct 2013
    rome new york
    I usually use 90 inch lbs
    Personally, I would not torque them If your torque wrench is not accurate you can easily strip these very small screws into an aluminum case. You get no real feel with a torque wrench. I use a stubby 3/8 drive ratchet and just carefully snug them. They do not need to be very tight at all and this is a much safer way to go. The O-Ring does all the sealing work and requires very little pressure to do so. The key is to run the screws down evenly putting uniform pressure around the O-Ring circumference. Where people get into real trouble is when they tighten 1 screw down all the way and then try to match it on the other side. Many a stripped case doing it that way.
    Dec 2019
    Thanks guys , wasn't sure how important it was to torque them .
