Results 1 to 14 of 14
    Active Member FIRECAT's Avatar
    Aug 2010
    WINDSOR,ONT,CAN
    Default 2019 F3 Limited heated grips
    Hello all as a snowmobiler I am used to heated handgrips for many years and they do get very hot on snowmobiles! On this new spider the factory heated grips are barely keeping up with the cold weather barely working very lukewarm is it me or that’s all that they get hot on they don’t get as hot as the rear ones for passenger is this normal????
    SNOWMOBILING ON PAVEMENT!!!
    Same here. 2019 F3L. They do not seem to be as warm as the ones on my 2014 RT-S. Those have a high and a low setting.
    Going to have mine checked out when I have my 3000 mile oil change in about three weeks.
    Feb 2019
    Portland, Oregon
    I agree -- the grips only get warm, not hot. It would be nice if they had two settings; ahhh and ouch!
    May 2016
    Tombstone Az
    They are just weak. Mine are the same do not get near as warm as my wifes RT
    Aug 2019
    Stoughton, WI
    Yup.. Warm at best.
    2022 RT Sea To Sky
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    I have no complaints on my RTL. Usually just use the low setting.
    2019 RTL Asphalt Gray
    2019 RT Limited , Asphalt Grey
    Sep 2009
    La Valle, WI
    BRP should offer a high/low switch upgrade for the F3 models.
    2018 F3 Limited , Oxford Blue
    Aug 2010
    WINDSOR,ONT,CAN
    Quote Originally Posted by JP58 View Post
    Well seems to be consistent there’s nothing wrong with them but coming from the number one snowmobile company of the earth you would think they could put some hot warmers on our spiders thoroughly disappointed
    Mar 2017
    Perhaps using another power source? Check my Heated Grips/Heated Pants page for how to do it.
    to see MY heated gear PAGE
    Mar 2013
    Marion, Arkansas
    I agree. The heated grips on the F3L have a lot of room for improvement. Do wish they had two heat settings like both of my RTS's had. I had SpyderPops check mine out last year when I had a lot of extra LED's installed on my bike. I believe he said that some of the 2017 F3's that the wires were installed wrong at the factory but he said mine were wired correct. I don't know if other years were effected or not.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Active Member bushrat's Avatar
    Apr 2017
    Peterborough, ON, Canada
    The stock grips on my 2017 F3L got fairly hot early on, when new; then, I added foam covers, after which they now only give me a warm feeling, at best. Anything added to the stock bars seems likely to markedly diminish the effectiveness of the hand grip heating coils. And, if you add arm rests for your passenger seat, you lose the rear heated hand grips entirely - they get taken off and replaced by the non-heated arm rests.
    [SIGPIC]
    2017 F3 Ltd. Intense Red Pearl/Metallic Black topside
    2017 F3Limited , lowered brake pedal Intense Red Pearl w. Metallic Black topside
    Active Member jerrydonna's Avatar
    Jun 2017
    Suffolk Va
    I picked up our 2019 f3L a couple months ago and it was a rather cold day. Our 2012 RTL hand grips got so hot on HIGH that I could almost drive with fingerless gloves down to 40. During that first trip home pressing the SINGLE button to turn heat on did cross my mind as to how that was going to work. Soon I to noticed that that HEATED grip was ****, even on low the 2012 grips are toasty. Hell I have to wear REAL Gloves now.. what a pain in the ass
    2012 , java
    Sep 2017
    Kentucky
    My 2016 rt special series would almost burn your hands on high setting, now my 2018 f3 s with brb grips with one setting are no where as hot
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    Yep. The heated grips on my wife's 2019 F3L suck as well. BRP needs to get them to be hotter. Pretty useless as they are.
