Results 1 to 25 of 36
    Apr 2013
    Hartsville, S.C.
    Default 2020 RT Customer Accessory Circuit
    I've looked through the 2020 RT owner's manual and see no mention of any electrical wiring for connecting aftermarket accessories. My previous F3 had two. Anyone know if they exist?
    Apr 2012
    Florida
    Following. Need to see the answer myself. Tom
    2020 Petrol Blue Metallic RTL
    Feb 2019
    Portland, Oregon
    In the absence of those wires, install a fuse block with a relay so it's only energized when the ignition is on. This will get your accessories isolated from the fussy Spyder electronics.
    Mar 2017
    Salisbury,NC
    they also make fuse blocks with switched / unswitched circuits, or power on / power off
    Aug 2012
    Central Coast, CA
    Use things that are listed as CANBUS safe in order to avoid issues.
    2020 RTL SE6
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by Woodaddict View Post
    I saw a really trick fuse block sold by either Lamonster or SpyderPops or perhaps someone else but it cost something like $80.00. And now that I want one I can't freakin' find it. If someone knows where, please lay it on us.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Feb 2019
    Portland, Oregon
    This is the one I used and added a relay so it's powered only when the ignition is on. Or you can pick and choose from the many of their fuse block page.
    https://www.banggood.com/DC12V24V32V...r_warehouse=CN
    Active Member rick_w's Avatar
    May 2013
    NE Ohio, Madison
    I have to pull ours apart to look at what type of connectors they are but the service manual states that there are front and rear accessory plugs.
    I can see them in the service manual schematics.
    I can not see anywhere in the standard manual where they are referenced.
    Rick
    Spyder Lovers Vendor
    Value-Accessories
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    I used a Blue Sea 6 ckt fuse box on my 2010 RT and bought another for my 2020 RT. I have not decided where to install it on the bike yet. Looking for ideas.
    https://www.amazon.com/Blue-5025-Bla...5479585&sr=8-4
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    Mar 2013
    Maumelle, AR
    There is one on the right side. I have my Garmin 590LM GPS hooked up to it. It's only powered when the key is on.
    2020 RT Limited , Chalk
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by upsdoctor View Post
    I used a Blue Sea 6 ckt fuse box on my 2010 RT and bought another for my 2020 RT. I have not decided where to install it on the bike yet. Looking for ideas. ......
    I have an F3L so your options may differ. I placed mine directly over the battery. It's powered through a relay that is energized only when the ignition is on.
    For others wanting to do a fuse block, here's where I got mine. They have several more, click the back arrow......
    Apr 2016
    Albany NY
    There is one on the left side (sitting on the bike) remove the upper black side panel,It is has 2 zip ties on it & a dummy connector on the end you need a EV1 male pigtail to plug into it or cut the plug off & use the wires. The wires are short, It is a keyed circuit.
    Active Member RowdyScamp's Avatar
    Aug 2019
    Arkansas
    2018 RT , Pearl White
    Feb 2019
    Portland, Oregon
    I bought mine here for $10.21 shipped. Look for it. They have a big selection of other fuse blocks.
    https://www.banggood.com/search/fuse....html?from=nav
    Dec 2019
    East Bay Area, California
    Timmb, do you happen to have any pics inside the panel showing exactly what you are referring to?
    Active Member NEXUS's Avatar
    Feb 2008
    Buckingham VA
    I ended up putting my accessory panel between the two in the front trunk.
    Easy to get to, battery connection right there, and you can zip it back up
    and will be out of sight.
    The accessory panel is a Tsunami TSFDB 14ATM this I'm afraid is no longer available
    or I can't find it on the Internet. I had bought an extra one when I put this on my 14.
    Feb 2019
    Portland, Oregon
    I did something similar on my F3L Sorry about the upside down photo. Note the relay that powers it.
    Feb 2020
    Ohio
    Feb 2020
    Glendale Arizona
    Quote Originally Posted by Flyback View Post
    That looks really clean!
    2020 RT Limited , Chaulk White
    Jul 2011
    columbus, georgia
    where can you source then EV! male plug? I went to several parts places no results. Next option is to wire direct.
    Jul 2011
    columbus, georgia
    left side. Remove access panel and look for a ev1` plug zip tied to a grouping. the top part is a cover only. If you have a male ev1 wired you can hook to the bottom piece. Other option is to cut off the bottom ev1 part and wire direct. i am attaching my gps here easier than left side.
    Feb 2019
    Portland, Oregon
    DoubleA....Is that a terminal block or a fuse block?
    Feb 2020
    illinois
    picture please
    Mar 2010
    Derry, NH
    I installed a Blue Sea fuse block and relay in the left saddle bag. IMG_3603.jpg
    Bob H - Derry, NH
    Feb 2019
    Portland, Oregon
    Nice work upsdoctor. I'm also ex Navy (CT) and should have installed a Blue Sea fuse block too!
