Results 1 to 11 of 11
    Active Member FIRECAT's Avatar
    Aug 2010
    WINDSOR,ONT,CAN
    Default Unpainted catalytic converter
    Hey Brp does a nice job finishing the whole machine except for the bare metal catalytic converter hanging on the bottom looks like hell! Has any of you spider riders ever attempted to paint it with a high heat paint? I have some high heat header paint able to withstand 1300°F has any have you attempted it and did the paint last or flake off?
    SNOWMOBILING ON PAVEMENT!!!
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    When my F3 was new, I simply cleaned my cat thoroughly with lacquer thinner and sprayed on a few coats of Rustoleum high heat paint. Thousands of miles later, there has been no flaking or peeling. Heating up the cat, the first few times, really "cures" the paint.
    Quote Originally Posted by FIRECAT View Post
    " Un-painted Cat " …. It's stainless steel - How much time do you spend lying on the ground looking at it ….. ???? …. Ride more - worry less ….jmho ….. Mike ………….However as " VitoNam " suggested that High Heat paint will work …. but it will get scratched and DIRTY
    indpls in
    you can always take it off
    Active Member RLS Exhaust's Avatar
    Mar 2019
    Waxahachie TX
    I sell the oem converter on ebay that are ceramic coated with cerakote this is a radiant heat barrier reducing the radiant heat up to 400 degrees https://www.ebay.com/itm/20273349540...84.m1555.l2649 and i also offer my cat delete that has a little deeper tone and also is available in the black ceramic coating https://www.ebay.com/itm/1330-Can-am...UAAOSwHDJcQXeF
    Feb 2019
    Portland, Oregon
    I have Ricky's cat delete on our F3L and he's not pulling your leg. It produces a deeper tone and no increase in the sound level.
    Aug 2010
    WINDSOR,ONT,CAN
    Thanks for your input I think maybe I’ll pull the whole thing right off and paint it with the high heat paint do it properly, is there a big job pulling this converter off just a few springs????
    Feb 2019
    Portland, Oregon
    It's not a complicated process, but the springs will give you a fight. Here's a step by step....
    + Loosen, but don't remove the muffler hanger bolt. You need two 15mm wrenches.
    + Undo the the clamp at the aft end of the cat. A deep socket on an impact driver is a great help to remove and replace the clamp.
    + Now you can undo the hanger bolt andremove the muffler. If there is a seal, save it and use it again.
    + Remove the 3 springs - easier said than done. They are tough and a spring puller tool did not do the job for me. What did work, was a stout, flat screwdriver that I used to pry them off. Did the same to re-attach them.
    + To remove the cat, observe where 3 rods go into rubber grommets and slip them out. Save any seals that were used and use again.
    You should be able to do this - my 10 yo great grandson removed the cat and installed the delete with my supervision.
    Houston
    I painted mine with VHT high heat matte black. Has never burned or flaked off.
    Mike, on the F3 the cat is clearly visible from the side of the bike due to lack of body work mid bike. Kinda sticks out, especially on darker color bikes. Painting it black makes it disappear or at least not be noticable.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Aug 2010
    WINDSOR,ONT,CAN
    Yeah it sticks out like a sore thumb on my all black F3 limited
    OK, I was thinking RT, OP didn't say what He had. …. and I don't always check to see what forum I'm looking at ….. Mike
