Results 1 to 8 of 8
    Active Member triplethreat's Avatar
    Feb 2020
    "Murvil", TN
    Default I need a quick favor.....
    I need two measurements for a 2018 or 2019 Spyder RT. First measurement I need is the center to center distance of the two front tires, as you are standing in front of the machine. The second measurement I need is the distance from the center of the front wheel (the center hub), to the very front of the bike (the front bumper/nose of the bike).
    I will be going to get the bike (out of state), and I need to get my trailer setup properly for strapping the bike down, so those two measurements are needed before I can install my E Track in the trailer......Thanks in advance.
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    2019 RTL
    center to center of two front wheels = 54"
    center of front wheel to nose = 20"
    2019 RTL Asphalt Gray
    2019 RT Limited , Asphalt Grey
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    Quote Originally Posted by Snakeyes View Post
    2019 RTL
    Didn't realize that the RT was wider than the F3. Center to Center on my 2019 F3 Ltd is roughly 51.5"
    Last edited by ARtraveler; 02-19-2020 at 11:25 AM. Reason: Pushed edit in error. No change to your post.
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Feb 2020
    "Murvil", TN
    2019 RTL
    Exactly what I needed. Thank you so much for measuring that for me. I can now get my trailer setup done this weekend and be ready to pick it up the following weekend.....I appreciate ya!
    Aug 2007
    Greeneville, TN
    Surprisingly, my Ryker is 53.5" center to center on the front wheels.
    Feb 2020
    "Murvil", TN
    Hey, I just noticed your location....you're about 75 miles from where I live....Maryville, TN. I'm 18 miles from Deals Gap
    Quote Originally Posted by LifeLongRider View Post
    Yes. The F3 is narrower. Noticeable since I also have an RT.
    Feb 2020
    "Murvil", TN
    I finished up the trailer yesterday with the E Track, spaced at 54" center to center and still had about 6 1/2" of space on both sides of the trailer (6' x 10' Utility trailer). I also planned on 25" from the center of the front wheels to the front rail of the trailer, giving me a buffer of 4 to 5" of space between the front of the trailer rail and the front of the Can Am. I also received my Erickson E Track Ratchet straps with the idler rollers and rubber pads for tie down over both front wheels. Here is what the tie downs look like....
    A Big Shoutout to SnakeEyes for providing the necessary measurements for this. I'm ready to go next Friday and pick it up.......after I get through another work week!
