Page 1 of 3 123 LastLast
Results 1 to 25 of 59
    Springfield, MO
    Default Rear Wheel Bearing Replacement
    Been doing a little research on the rear wheel bearings on our Spyder. The BRP bearing crosses over to a NSK 6205
    I've found these anywhere from $20.00
    http://www.replacementbearings.com/i...05VV&OEMFlag=0
    to $3.24 for the same bearing.
    Here's a link to the cheaper ones.
    [ame="http://www.amazon.com/Bearing-Precision-Sealed-Groove-Seals/dp/B0020KXM0I"]Amazon.com: Bearing, 25mm I.D. x 52mm O.D. x 15mm Wide Precision Sealed Deep Groove Ball Bearing  Two Seals: Industrial & Scientific[/ame]
    It might be good to keep a couple of these as spares if you're on the road and need to replace them.
    Mod Maniac
    May 2008
    North Texas
    Good job, young man. Let us know if they actually work.
    May 2009
    Hobart, Tasmania.
    Thanks Lamont, are they sealed (2RS rubber) or shielded (ZZ metal)
    These are 6000 series bearings and are made by lots of top brand manufacturers like SKF, NSK, etc and should be available from any good bearing shop.
    Are all three the same bearing.
    Mar 2009
    Central IL
    Be wary of counterfeit stuff online. Something like a bearing I would want to know it is not some cheap chinese one.
    Springfield, MO
    Quote Originally Posted by gazey View Post
    Springfield, MO
    Quote Originally Posted by Longlegs View Post
    We have China tires on the Spyder now so I'm not sure we don't have China bearings too. I have stock and these coming so I'll let you know.
    Senior Member
    Apr 2008
    Naples, Florida
    How about the double-wide bearing in the sprocket? The 2009 wheel bearings have a different BRP part number. Do you have a cross-reference number for these, or are they not physically different?
    I sent an email to Carlo with similar questions - will post the reply when I get one.
    Senior Member
    Apr 2008
    Naples, Florida
    Quote Originally Posted by Lamonster View Post
    The 2008 stock bearings were made in China.
    Springfield, MO
    Quote Originally Posted by Spyder1026 View Post
    I have one of those coming too and when I get it in hand I'll see what the match is.
    Mar 2008
    East Dubuque, Il
    WOW. If memory serves me right those are the same bearings they use in the bogey wheels one their skidoo snowmobiles. I will have to go out im my sled parts box & check. Small world isn't it?
    Quote Originally Posted by dabreitbach View Post
    Makes sense...why re-invent the wheel? (no pun intended)
    Invalid Emails
    Jun 2008
    San Diego, CA
    Here's another if you want a better quality ceramic bearing..
    http://www.bocabearings.com/main1.as.../TH9/C4_#3_NB2
    Quote Originally Posted by Wheelz View Post
    Wow! Really! Ceramic bearings... Sounds great but I'd think they would not handle shock loads well. It says for off road use though.
    Interesting!
    Springfield, MO
    $90.00 I guess it would be worth it if they never failed.
    Active Member Just Doo Me's Avatar
    Aug 2008
    Millbrook,Ontario
    Royal Distributing in Canada sells this size ,it is the same as the Ski-Doo idler wheel bearing as well as a few other uses. pg 185-186 http://www.royaldistributing.com/Sho...w2009/185.html
    Springfield, MO
    Quote Originally Posted by Just Doo Me View Post
    10 pack for $34 bucks
    May 2008
    Kingsport TN
    Default Ceramic bearings
    BRP had problems with the ceramic bearings in the superchargers on the jet ski's and supercharged jet boats and replaced them,with stainless steel, I think, but I know they had problems with the ceramic.
    Springfield, MO
    Here's the stock BRP bearing.
    Mar 2009
    Central IL
    I wasn't trying to say all China stuff is bad, but when I have gone to the bearing store they always ask if I want a china bearing or a good bearing. This started me thinking; if the bearing says china, is there one big factory that makes all of the "china bearings" or is there a chance that some come fom better quality sources? Maybe a high school factory versus kindergarten factory
    May 2008
    Shawangunk, NY
    Wink china bearing
    +To get your China bearing simply means you face east as you pay...
    (What?)
    Ride on.
    Roadkill
    2008 GS Roadster , Roadster Red
    Mar 2009
    Central IL
    Quote Originally Posted by Roadkill View Post
    (What?)
    Ride on.
    Roadkill
    Well I'm in Illinois so it's closer for me to face west.
    I think this is due to initial offerings from China that were absoulte junk. Just like when Japan started making things their stuff was junk.
    China has been working on their quality control issues. They still put out a lot of junk and I'm not saying their bearings are as good as those made in the US.
    On the other hand, some China bearings may be as good. They are certainly much better than they were. But they did earn a reputation and it will take quite some time to live that down.
    Plus, there is a growing animosity towards products made outside the US (since almost nothing is made here anymore). Another reason you may be getting this statement for your parts guy.
    Trouble is, even many good old US made bearing name brands are now being produced in China or elsewhere.
    Invalid Emails
    Mar 2008
    Spooner, Wis.
    Well I hope I don't need to replace these bearings, But if I do how hard are they to replace?
    Springfield, MO
    Quote Originally Posted by Putt-Putt View Post
    It's not bad but I would have your dealer do it if you've never done it before.
    The nice thing is you can take the hub apart so you can knock the bearing out from the back side without a special tool.
    Springfield, MO
    Got my bearings and they look pretty good.
    They are made in China.
    The inner race seems to be a little thicker than stock.
    They turn smoother than the stock bearing I have in hand now.
    The two black bearings are the new ones and the red bearing is the stock one.
Tags for this Thread
