Results 1 to 12 of 12
Thread: Loud shifting
    Mar 2019
    lakewood ranch fl
    Default Loud shifting
    Most of the time my 2019 f3L shifts quiet, but today it was very loud mostly Down shifts. Check oil good the bike has less then 3000 miles . What would cause this ?
    Nov 2018
    Lisbon, Portugal
    How loud is loud...
    Mine definitely is louder downshifting.
    I believe the first service is due at 3000mi (oil change).
    See: https://www.spyderlovers.com/forums/...on-F3-S-tranny
    2018 F3S , Monolith Black Satin
    Mar 2019
    lakewood ranch fl
    Most of the time its just a click , but yesterday it was a more metallic clunk on down shifting same as me or auto up shifts were loader as well . how does this change on one day to the next ? its got about 700 miles before the 3000 mile service and being broken in .
    Nov 2016
    Palm Coast, Florida
    I was hearing the same loud clicks when upshifting so I changed the oil at 3000 miles with a full synthetic oil . It made a big difference, the shifts from 1-2 and 2-3 I get a slight click. From 3rd on up its pretty quiet. The downshifting was not an issue with mine.
    Florida Swamp
    I am not saying the shift did not get louder in just one day, but think about if you maybe wore a different helmet, or changed the windshield angle, or maybe just got over a head cold.
    2019 F3-S , Black & Silver
    Mar 2019
    lakewood ranch fl
    NO every thing same , but the sound when it down shifted , my wife on the back also commented on whats up . will take it for a ride today and see if its the same ,
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    hi bear
    mines noisier if i dont shut the throttle right off when downshifting
    russ
    pres ride
    2014 RT-S
    bike is WIP
    bike has endured elect spike (was jump started incorrectly)
    still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
    Dec 2017
    Emmetsburg, Iowa
    Turn up the radio
    2018 F3 , Full size brake pedal Black
    Nov 2018
    Lisbon, Portugal
    Quote Originally Posted by merlot View Post
    hi bear
    russ
    I'll second that. Close the throttle for downshifting, keep it open for upshifting.
    Mar 2019
    lakewood ranch fl
    Thanks for all the input . I have been very careful on the throttle , some days with all conditions same , smooth as silk , other days metallic clunk 600 miles to 3000 oil change and end of break-in . Just going to live with it and at service get full synthetic oil .
    Greenville Tx
    Someone posted a video a while back discussing this issue. in a nutshell it said the transmission on our Spyders is what they use in race cars and are loud and clunky but very durable. Ryde it like you stole it.
    2017 F3 Limited
    Greenville Tx
    The only issue I have had is after the first oil chang I did on it, I went on a ryde and when I got to the gas station, it would not want to shift into first. come to find out, I had not read the owners manual correctly on how much oil to put in. It says put 5 quarts in then get it to operating temp and add more to get close to full. I was on the min mark. It was OK to ryde the day like that but I added more when I got home and from then on, It never happened again.
    2017 F3 Limited
