Results 26 to 50 of 52
  1. #26
    Apr 2012
    Florida
    My belly doesn't allow me to get under anything anymore. Tom
    2020 Petrol Blue Metallic RTL
  2. #27
    Quote Originally Posted by Gwolf View Post
    I don't ride it around to make it flow better. I ride it around to get all the particles that have settled out in various places inside the engine and transmission stirred up into the oil so that more of them will come out when the oil is drained.
    … so your engine … KNOWS … the Spyder has / is been actually moved on a road surface …???? …. well yours is waaaaaaaaay smarter than mine ….. Mike
  3. #28
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    I also drove mine around prior to me doing the oil change rather than just letting it idle to warm up. Folks told me that the oil in the engine crankcase doesn't know the difference, but it gets the "stuff" in the transmission side suspended so it will flow out easier. Plus, it was a nice day! Carry on....
  4. #29
    Feb 2019
    Portland, Oregon
    Gwolf, I'm with you and will add that I plan my oil changes to be at the end of a long day ride. I pull 'er into the garage and pull the plugs. Only downside of this method is, the oil is damn hot if it hits your hand. Don't ask.
  5. #30
    Well it seems from some comments that the Rear wheel somehow moves the oil through the engine …..AMAZING …. what you can learn on this site
  6. #31
    Florida Swamp
    My engine don't know anything, but I know if the gears in the transmission are spinning or if it is just sitting there idling. I also know it will stir up more of the particles if it is run through the gears than it will if it just idles a while. The oil is not just in the engine. It also circulates through the transmission.
    Believe whatever you want to. I will do it my way. You can do it any way you like.
    2019 F3-S , Black & Silver
  7. #32
    Feb 2019
    Portland, Oregon
    Differences are what makes horse races.
  8. #33
    Active Member iridenow's Avatar
    Sep 2019
    Phoenix, AZ
    Quote Originally Posted by Tango View Post
    Anywhere from $200-$300 is about where all the dealers are. Remember they do labor by the "book time" and parts are full retail. Hopefully it is all done by a Spyder certified tech.. Car oil change for $19.99? Done by a kid right off the street. Probably still reading comic books. Tom
    Yep....and done in 10 minutes at the Quickie Lube down the street.
    Fred is a 2010 RT SM5 - Sold.
    I am not a mechanic. When I have a tool in my hand, 911 needs to be on Standby.
  9. #34
    Jul 2017
    Huntsville Alabama
    I don't see anyone saying that. I see Gwolf, me, and others saying that actually riding the Spyder spins the transmission gears, which contain the same oil that you change when you do an oil change. Spinning the transmission helps to temporarily suspend particles so that they can more easily be removed during the oil change, while at the same time warming the oil for easier flow.
    If we were talking about a typical car, where the transmission fluid is a totally separate system than the engine oil, that would be different.
    Anyhow....flame on
  10. #35
    Clinton, MS
    Idling in neutral would also spin the transmission gears. However running up the gears over the road would cause a heck of a lot more stirring up of anything that might be settled.
  11. #36
    Florida Swamp
    Idling in neutral spins only the input shaft. Without any of the gear pinions engaged the output shaft does not spin.
  12. #37
    Clinton, MS
    Yep, kind of what I was referring to, guess I could have made the point clearer.
  13. #38
    Let's agree to dis-agree ……… Debris , particulate matter etc. is going to be heavier than the oil it is in ….. and if that is the case, when the oil isn't moving that stuff will sink to the bottom of whatever it is contained in ie. engine, transmission etc. the magnets on the drain plugs should be catching any steel / iron metal parts ( that's why they are there )….. and I don't stop my engine and immediately pull the drains, I might wait 15-20 minutes. … I've owned many, many various veh's in my 72 yrs. and never had an engine or transmission failure...… Thanks for all your opinions …. Mike
  14. #39
    SoFlo
    Its not about the engine, its all about the gearbox and wet clutch...just so happens, the engine must be running to spin the gearbox and clutch.
    Circulated oil that has been run prior to draining, and yes it may sit a few minutes, will suspended, aluminum particles, and moisture or acids if present and do a better result removing them.
    Will you see immediate failure, have your engine blow up or see detrimental effects from draining cold oil. Very unlikely no, however it is simply not the best method to use.
  15. #40
    Aug 2019
    Stoughton, WI
    I, too, am in the ride before oil change group. After 50'sh years, won't change now ...
    2022 RT Sea To Sky
  16. #41
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    I'm also in the school of riding it and immediately changing the oil because of the very reason stated above in which a lot more of the particles are suspended in the oil.
    I'm also in the school of do it right, or don't do it at all, but whatever "floats" your particles....erm, I mean....boat.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
  17. #42
    Active Member deer30084's Avatar
    Tallahassee, FL
    Shell Rotella T6 meets JASO MA/MA2 specs so it is safe for wet clutch. $23.00 gal at Walmart. K&N oil filter with all o rings from Bajaron $19.95 and he ships fast. Won't pay the $90.00 for the oil change kit at the dealer again and certainly won't have the dealer do my oil change. I believe "if you want something done right, do it yourself." Of course, you've got to know your limitations.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
  18. #43
    Dec 2019
    Land of Lincoln
    Quote Originally Posted by Raprider View Post
    I agree with you on the first and last parts of your statement, but...
    1 gallon of Shell Rotella T6 5W-40 is $23 at Amazon or WalMart...so figure about $35-40 for 6 quarts worth.
    Add about $15-20 for the oil filter, o-rings, etc. (edit: I see another thread where you posted some filters for about $5 +/-, so maybe your estimate isn't that far off!)
    A full kit with oil and filter and o-rings from Lamonster is $85-90, depending on 998 or 1330.
    As PMK stated above, maybe if you're stockpiling when a sale is available, you can shave a few bucks here and there.
    I do stockpile some if the price is right.
    Currently, I could change a 1330 for right at 28.00 . BajaRon o-ring kit from eBay at 12 shipped, an Outlaw filter for 4.50, and 6 quarts of Castrol Power 1 from an AutoZone sale at 2.00 per quart.
    The average Joe doesn't need to hoard oil, there are plenty of good deals every day if you look.
    Grainger has Mag1 @ 4.00 a quart available and free ship for pickup. The name doesn't do justice to what's inside. A really good, under the radar oil made by a major blender that does a bunch of private labels.
    WalMart recently had Quicksilver full synthetic on line at 37 for a 12 pack. That's the lubricant division of Mercury Marine: they got into powersports a while back. Made by Citgo, which BTW, is the folks that bring you Yamalube.
    And every late October, early November, AutoZone closes out all the slow sellers. The mentioned Castrol was there last fall. I did get a few of those.
  19. #44
    Quote Originally Posted by Baron14y View Post
    Amsoil full synthetic, Amsoil filter, labor, $90.00. Done at a shop that works on a lot of Spyders.
    I do not believe that Amsoil makes an oil filter for the Spyder. I certainly cannot find one. I'd love to get that part number if you are able.
  20. #45
    Quote Originally Posted by Peacekeeper6 View Post
    This is one of the big advantages of doing your own oil change. Getting the oil hot makes it flow much faster. Faster flow removes more contaminants and debris. These contaminants settle out and lay on the bottom after a relatively short time. Just idling your Spyder will not do the job. And the shop does not have the time to ride your Spyder before doing the oil change. They might not even start it up. It's just too time consuming. If the engine isn't run long enough to warm the oil, and if you don't ride your Spyder for a few miles first to agitate the oil with the gears in the transmission. You are leaving a high percentage of settled out particles just waiting to contaminate your brand new oil.
    As mentioned by others, the transmission and wet clutch also run in the same engine oil. The clutch has fibrous friction plates (like brake pads that work in oil) which run up against steel plates. And, just like brake pads and rotors, they lose a little bit of material every time you engage the clutch. Granted, it isn't that much. But it tends to settle out pretty quickly when the engine is shut down. A magnetic drain plug will catch much of the ferrous materials. But it isn't going to get any of the clutch fibers or any non-ferrous materials. You can get nearly all of this material out with a run and hot drain. You are leaving most of it behind with a cold service.
    It's not a matter of life and death, by any means. It's just the difference between doing it, and doing it right.
    This is why the pull through oil change stations for cars/trucks are such a good deal. You drive in with hot, circulated oil and you are removing nearly all of the built up junk that has accumulated since your last change. It really is a better way to go.
  21. #46
    For the Spyder. All that needs to go under is your head. The belly can stay somewhere else.
  22. #47
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Apparently you are right. I will call the dealer and find out what (if?) filter he put in.
  23. #48
    May 2019
    Palm Bay, Florida
    Dealer used a HiFlow HF556. Same one BajaRon supplies.
  24. #49
    Nov 2017
    San Francisco Bay area
    When I was in Alaska, $350 was the oil change price. Labor rate $130 per hour.
    Thats what I got quoted from a place 40 mins from where I live. The place an hour 40 away was 225, guess where I'm going....
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
  25. #50
    Quote Originally Posted by LeftCoast View Post
    Probably the longer distance one, you want to go for a nice ryde.....right??
