Page 1 of 3 123 LastLast
Results 1 to 25 of 52
    Sep 2016
    Clifton Springs, NY
    Default Vredestein Quatrac 5 tire question
    Hello, I put Federal Formoza tires on the front of my RT a couple of years ago and like how they really smoothed out the ride. I would like to change out the fronts on my F3L also and based on all of the good feedback I am thinking about going with the Vredestein tire. The question I have is I can buy (2) Federal Formoza tires for about the same price as (1) Vredestein. Are they really that much better and worth the difference in price?
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
    Quote Originally Posted by wrb3004 View Post
    Up to about 6 mos. ago no one here had been using the Vredestein Q-5 tire. I discovered it, and learned it is probably the best tire currently available that will fit the Spyder. … I have been recommending it ever since, because it's traction wet/dry exceeds all the rest …..that being said, I would not say that traction is twice as good as the Federal's. So from a cost / value point the Federal's are a much better buy. Since you said " Two ", I'm thinking front tires. For any Spyder front traction is not as critical as REAR traction. … The Spyder has Computer influenced TRACTION properties, but they don't over-ride the REAR tire as far as acceleration and stopping goes... I'm all about safety - and IMHO the Q-5 provides the best overall traction …. good luck ….Mike …………….PS, the members here who have the Q-5 say they Love them …..
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    I'm happy with mine. Better than the Kendas that they replaced( which were not worn out). I don't have a lot of miles on them yet but they do have a stiffer side wall and react to steering input more confidently.
    Lew L
    2014 RTS , Circuit Yellow
    Jan 2015
    southern WI
    If you're satisfied with the Federals, just go with them. I put a set of Q-5's on but don't have any miles on them yet. I don't mind spending $160 for 2 tires. Looking forward to seeing how much better they are than the stock
    2016 RTS , Pearl White
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Lew L View Post
    I'm happy with mine. Better than the Kendas that they replaced( which were not worn out). I don't have a lot of miles on them yet but they do have a stiffer side wall and react to steering input more confidently. Lew L
    "MINE" being Q-5 or Formoza? Inquiring minds want to know.
    Mar 2015
    For the curious -------
    Vredestein Q-5
    Member 4boywonder6's Avatar
    Feb 2016
    Tucson,AZ
    Where can you buy the Quatrac 5 tires?
    Aug 2019
    Stoughton, WI
    2022 RT Sea To Sky
    Feb 2016
    Tucson,AZ
    ok--I just looked and they didn't have much for the Q5s
    Member ransman's Avatar
    Feb 2017
    alabama
    Got mine at Vulcan Tire.
    Feb 2020
    N. Wilkesboro, NC
    Two questions, please. First, what size would I need (front/rear) for a 2018 RTL? Second, I ride year round (I'm in NC). I've ridden in rain all of my life. I haven't had the "opportunity" to ride in snow on the Spyder yet as we've only had about an inch total all winter. How are the Q5s in rain? How are they in snow?
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by 4boywonder6 View Post
    Front tires ? Right here .. https://www.tirerack.com/tires/tires...5QT5&tab=Sizes
    2022 RT Sea To Sky
    Quote Originally Posted by MONK View Post
    With a 15 wheel there are a few choices in sizes that will fit in the Q-5's …. rear they make a 205/60 & 65 that will also fit …. Rain - the Q-5 has the best rating I've seen so far … snow - no other All season tire comes close unless you are going to mount a real Winter ( not likely )… they aren't widely distributed but are woth looking for … try Vulcan tire , Simple tire, and tire rack ….. Mike
    Feb 2020
    N. Wilkesboro, NC
    $277 all in for all (3) tires, shipped to me (not that I need new tires right now). That's dirt cheap. I just paid double that for the (2) tires I put on my Kawasaki Nomad.
    …..folks who are actually looking for this tire, would like to know who/where did you buy …. and what sizes did you get ….. Thanks …. Mike
    Feb 2020
    N. Wilkesboro, NC
    Metzler Cruisetec on the front and Dunlop American Elite on the rear. Both are dual compound and others are getting great mileage. They're pretty sticky, too. I'll have to look on the tires when I uncover the bike next for the sizes. Bought them from my LBS.
    Aug 2019
    Stoughton, WI
    What size AE do you have on the back ?
    2022 RT Sea To Sky
    Feb 2016
    Tucson,AZ
    thanks
    Feb 2017
    Absolutely. That's where I bought mine. Same size and price as indicated in the link. Paired with a set of PPA wheels and I'm very pleased with the improvement. Thanks Mike for the tip several months ago now.
    Quote Originally Posted by Arion View Post
    Your welcome - please keep us posted about how you like them ...…………. Mike
    Feb 2016
    Tucson,AZ
    I looked a the current size on the bike and the ones on tire rack are not the same, I'm guessing a little taller or a little wider is not that big of an issue?
    my current
    165 55 R15
    225 50 R15
    2014 RT
    Aug 2019
    Stoughton, WI
    Correct .. 165/60R15 works really well. Some run 165/65R15 but I didn't want to go any taller than the 60 profile. Vredestein rear would be 205/60R15, a bit narrower. many here run it and like it. That tire is available here .. https://www.vulcantire.com/cgi-bin/t...quatrac5_s.cst
    2022 RT Sea To Sky
    Feb 2016
    Tucson,AZ
    great--thanks for the info
    Feb 2016
    Tucson,AZ
    another question on the Quatrac 5s ,is the air pressure still the same as OEM tires?
    Aug 2019
    Stoughton, WI
    17.5# for the front seems to be the recommended pressure. Not having a Vredestein rear, I am not sure.
    2022 RT Sea To Sky
