Results 1 to 9 of 9
    Nov 2019
    Kansas
    Default These push pins work for panels?
    Bought these, but look a bit different
    And can't get them to work
    Will these work?
    Jul 2014
    Mint Hill, NC
    Your photo appears to me to show only one piece. Spyder push pins have two pieces like the ones in the top row of this link:https://www.amazon.com/GOOACC-Retain...30689150&psc=1.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    I use these and are as close as I've found to what BRP uses, and a LOT less expensive: https://www.ebay.com/itm/100-pcs-8-m...53.m1438.l2649
    Nov 2019
    Kansas
    I ordered those on ebay. thank you
    Nov 2018
    NW Minnesota
    Quote Originally Posted by acdcking12 View Post
    You are welcome! Those push pins are the best deal going, so it's easy/cheap to replace one you might have screwed up lifting those suckers out. With the proper tool even.
    Active Member Tec35's Avatar
    Dec 2019
    Rhode Island
    You can also grab them on Amazon
    100 PACK - Premium Venom Brand... https://www.amazon.com/dp/B07W627S5F...p_mob_ap_share
    2017 F3 limited , Black
    Nov 2018
    NW Minnesota
    Thanks for the info. It's always good having more than one source to choose from. Premium VENOM. Gotta love that name!
    Dec 2019
    Land of Lincoln
    Push pin pliers can help remove them without damage, but it is really nice to have spares on hand.
    https://www.harborfreight.com/push-p...EaArwBEALw_wcB
    Nov 2018
    NW Minnesota
    Here's another handy push pin tool that works well. For the one I have, I modified the tool's head by grinding down the flanges, on either side of the opening, leading down to the shank just a bit. It reconfigured the overall shape of the head. For me, I found the tool works better that way getting under those pesky pins.
