Results 1 to 3 of 3
    May 2020
    Clifton, Colorado
    Default 2013 spyder high pitched noise at rest and won't crank
    won't crank and a high pitched noise at rest...sad
    Sep 2012
    Stetson, Maine
    Please provide a little more info.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Nov 2015
    Chardon, OH
    After you turn the key off on the 998, the throttle body actuator is still energized for about 40 minutes. You will hear a high pitched whine. Completely normal and not related to "won't crank".
    Many steps in the engine starting sequence will prevent the motor from cranking even with a good battery - such as Mode Switch not depressed at the safety card screen, Kill Switch not in run, Brake not depressed if not in Neutral, Clutch not pulled in if an SM5. Go back through your owners manual on pages 44 and 45 and see if you haven't forgotten anything.
    Doug
    ”Freedom is not a loophole”
