Has anyone moved the shifter assembly from LHS to RHS?
Has anyone transferred the shifter assembly from the left side of the handlebar to the right side on a 2013 or newer Spyder?
Shifter assembly
I don't know if that would be practicable on the electronic shift. You could do it with the manual shift, maybe with something like the Pingle Shifter that many Harley riders use. Or if your left foot works ok you could put a clutch lever on the right.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
It's for a friend of mine. We transferred the electronic shifter on his 2010. The shifter was upside down, but worked perfectly. He's purchasing a newer bike, but we're just not sure if it's doable with the new shifter style.
Also looking for a solution to this, if I find anything out I will post my solution
I distinctly remember reading about someone who has done this here on this forum! I will see if I can find it but if you use the search function and then the "advanced" option it usually returns what you need.... ;-)
EDIT:
Did you see this post?
https://www.spyderlovers.com/forums/...-controls-only
Chuck
