F3 Top luggage box
How hard is it to remove the top luggage rack on a F3.... As, if you want to ride around with it, then put it on for a longer trip. ( I see that option is now available for the 2020
RT )
The 2020 RTL and F3L have the linq system. Probably remove in less than a minute. Turn the release nob and unplug 1 connector. My 2018 F3L about 5 minutes. Remove 2 screws under the mat. Lift up unplug antenna, usb connector, and brake light plug. Remove.
