Results 1 to 18 of 18
    Dec 2019
    VA
    Default GPS Installed, differently
    I took the GPS off my old bike before I traded it in so I needed a way to mount it. The BRP mount is nice, but way more than I wanted to spend. I've seen a couple other top clamp mount plates, but they all seem to use Ram mounts which are great if you need the adjustability but seem too much if you don't. So I grabbed some calipers, a couple bits of scrap aluminum, the lathe, the mill, and the welder and made my own. It would have been much simpler to make from steel but I need the practice with aluminum and I could always redo it later. Also I haven't wired it yet because I'm waiting till I decide which heated grips I'm installing so I can do both at the same time.
    Untitled by Uncle Grr!, on Flickr
    Bracket with wrinkle finish paint
    Bracket bottom
    Bracket installed
    Mount on GPS
    Mount installed
    View from the driver's seat
    2019 F3S SM6 , Black metallic with pearl color change
    Active Member pieman9155's Avatar
    Aug 2019
    upstate NY
    Looks good
    2019 f3t , titanium
    USA
    Nice. I like to see DIY'ers, especially of this caliber.
    h0gr1der
    Jul 2011
    Mitchell, Ontario, Canada
    Very nice!
    Aug 2019
    Stoughton, WI
    Very cool !
    2022 RT Sea To Sky
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Clinton, MS
    Great job. Interesting project.
    Quote Originally Posted by h0gr1der View Post
    …. …. I've DIY'ed 80 or so parts for my 2014 RT …… very nice …. Mike
    Mar 2013
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Active Member Greven's Avatar
    Oct 2019
    Sweden
    Looks factory! well made! Double thumbs up!
    Mar 2017
    I made a simple bracket with 14 gauge steel bent. Mounted to the existing bar clamp with #10 screws. I love it. Yours looks great! Minimalist of which I am a fan.
    to see MY SPYDER PAGE
    For heated grips, make your own. to see MY heated gear PAGE
    SoFlo
    Way cool, looks sweet and the location is clean / uncluttered.
    Seeing the install on your Spyder, if mine I would somehow black out the fasteners to make them disappear.
    Mar 2017
    Just paint them black with Duplicolor truck bed liner. Matches the textured OEM PC. Touch ups are invisible. Just spray into the cap and daub on with a little brush.
    Dec 2019
    VA
    Using the excellent advice of Rattlebars (Thanks!) I picked up the correct connector from amazon for small money, soldered that onto my existing GPS harness and got the whole thing wired up.
    Wire routed, ziptied to OEM harness.
    Connected to OEM GPS connector. I added a few more zip ties after the pic was taken.
    Powered on with the key
    Mar 2017
    Looks great! Factory! What model Garmin??
    Dec 2019
    VA
    Thanks! That's a Zumo 396. Took it out for a ride the other day with my wife (her on her Ryker) and the GPS was in the perfect spot.
    Mar 2017
    Quote Originally Posted by whodat View Post
    Looks like a nice unit! Please let me know if the "curves ahead" and other warnings works well and if you can turn it off. I had a Garmin 56 that included those warnings and the first time I took it out in the mountains on my Cleo Chapman Highway route (made it in Base Camp) it would sound all the time to the point it locked up the upper bar where it once had told me what turn was coming up! Really bad. My 57 doesn't but still bugs me with school zones whether or not they even exist or not. Injoy!
    You can see my Ohio and some South Carolina routes with downloadable gpx and kml files for garmins and map illustrations like shown.
    to see MY maps PAGE
    Active Member Catalyst105's Avatar
    Jan 2020
    Florida
    That is a great job, and next level DIY project. Metal is the last medium I have to learn how to work with and fabricate.
