Results 1 to 7 of 7
    Very Active Member fireplug98's Avatar
    Sep 2011
    Arden Hills, MN
    Default larger sprocket and belt
    Hey all !!
    2019 F3L
    Has anyone changed their sprocket and belt to the larger one without ECM flash ??
    Tommy J.
    F3L SE5 Black -- F4 windshield w/wings, Reggie LED headlights, driving lights & Cyclops LED, Ultimate seat, Fox shocks, BajaRon swaybar, Lamont highway centerline pegs & 3rd peg, Lamont belt tensioner, K&N air filter, Baker air wings & cup holder, CanAm hitch.
    2019 F3L , Black
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Tommy, I don't think anyone has done it successfully, with or without a ECM flash.
    2020 RT Limited , Petrol Blue
    Apr 2019
    Florida Swamp
    The Limited comes with 28/79 final drive ratio.
    The F3-S and Base model F3 comes with 28/ 89 final drive ratio.
    This is true for North American sales models.
    I don't know for sure, but it might be possible to install the pulleys and belt from a stock F3-S on the Limited.
    It is also possible the different fenders, belt guards, etc would interfere with the larger rear pulley. It might require some modifications to do the swap.
    Speedometer would be wrong. Might also run into some other, more serious problems.
    2019 F3-S , Black & Silver
    Mar 2017
    the computer does not like the different gear ratio!
    Sep 2013
    Houston
    The sprockets and belt can be physically installed with out much trouble. The nanny does not approve and the settings in megatech BUDS are as yet unknown. There is a setting for the rear sprocket size but changing this alone does not fix things.
    The short answer is that no one, even with an aftermarket tune, as been able to make it work. If you want the large rear sprocket, buy an F3S.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2017
    My 2016 T has the 89 tooth listed also 2017
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by Rattlebars View Post
    2017 was the last year for the 89 tooth on the F3-T. From 2018 on, the F3-S is the only one with the larger 89 tooth sprocket.
