2020 RT Limited - do they still get the old Kenda tires?
Do the new RT Limited's have the new Kenda tires or are they still using the same old junk Kenda's as always?
Toby
Reason: Title
2020 RTL
From my read here, still using the 'old' Kenda's.
Thanks, I will have to take that into account if I fall in love with one when I do a test ride on Saturday morning.
Have not had very much luck with the old Kenda's on my other Spyders.
Toby
2020 RTL
If the 'new' Kenda's are 'as advertised', a vast improvement for less $, we shall see.
2020 RTL
RT-S PE#0412
Toby
I took this picture of the tire on a new 2020, aren't these different than the old Kendras?
Ozzie Ozzie Ozzie
Originally Posted by TicketBait
I took this picture of the tire on a new 2020, aren't these different than the old Kendras?.......
Nope, same old Kendas!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Actually it's not the same. The center tread on that tire is straight. The old kendas have bump outs every couple inches. But outer tread is close to the same.
Here's the Kenda tires shown on BRP parts page. https://can-am.brp.com/on-road/shop/...rts/tires.html
The tread pattern is slightly different. So question is, is it the same tire with a newer tread pattern, or the Kanine w/o the Kanine name? Who knows?
2014 Copper RTS
They're new production Kenda, so time will tell if they're any better. When I bought my last RT in 2014 the rear Kenda only lasted about 4k miles.
Reason: sorry for the edit....wrong button
2020 RTL SE6
I'll never go back to Kenda if I can help it. There are so many other better choices out there.
2020 RTL SE6
When we moved to AR, I immediately replaced the Kenda's with "darkside" tires on both the 2011 and the 2014. The 2011 has been traded off and someone got a brand new set of tires. The 2014 is now my beta test bike for "darkside" tires. My new F3, has Kenda's all around. I have three years or so to make a choice there.
