Results 1 to 6 of 6
    Very Active Member freebob's Avatar
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Default 2010 RT SM5 reverse inop
    Anyone had reverse lock out fail? My 2010 rt sm5 will not let me get into reverse gear, has anyone had this problem?
    And what was fix to solve this... I have tried everything....
    freebob..
    Nov 2018
    Claremore, Ok.
    Have you checked the shift lever on the transmission? See if the shaft has slipped back out a little, or if the lock bolt is even still there.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    That's where I would also look first. I believe it is called the "shift actuator." Been there, done that.
    Nov 2015
    Chardon, OH
    So, how's this going Bob? It's been a few days. I understand that you have a MANUAL transmission, and that everything operates properly in the forward gears. When you push down on the Reverse button, it still doesn't let you go into reverse?
    OK, so folks have had issues with the button just getting a little finicky and not going all the way down. Solved with a LITTLE spray silicon lubricant around the edge and exercise it. Plus, if you don't already, pull in the clutch with your left hand and operate the button with your right thumb. If all of that is ok, check fuse F7. Don't just look at it, but replace it with a good fuse. The reverse actuator and the optional trailer module are the only two things coming off that fuse.
    Other wise, you will need to check out this mechanism underneath. Have someone operate the reverse actuator while you watch and see what's going on. Just may need to unplug the connector, spray it with contact cleaner and plug it back in. Possibly a cable adjustment is required, the cable broke, or the actuator may have failed. Highest probability is the button acting up or the fuse. Good Luck.
    Doug
    ”Freedom is not a loophole”
    Sep 2012
    Stetson, Maine
    Great advice from above posts. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Quote Originally Posted by freebob View Post
    freebob..
    Bob, did you get this issued resolved?
