I think your good. If you get a vibration set your belt tension at or near the low end of the scale. Down around 160/170 or so. Other posters have said vibes go away in those setting ranges.
If all is well then you don't need one..dont just add one because you think you need one... If your getting vibes then try find out the cause rather than add a tensioner to mask it.
