Results 1 to 8 of 8
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    Default How to Remove Hitch
    Need to remove the hitch from my F3L. Can someone talk me through it? I know the axle bolt has to come out. Will the wheel move? Or does it all stay in place? Do you put the same bolt right back in? Anything else to remove? Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Very Active Member NautiBrit's Avatar
    Jun 2008
    Buckeye, AZ
    Pull the bolt, then wiggle (I used a rubber mallet) the hitch off of the swingarm. Be very careful that the hitch does not catch on the abs sensor and/or brake line.
    George
    2017 BMW R1200R
    May 2017
    Mesa, Arid-Zone-A
    What you are referring to as the axel bolt is not the axel bolt. It is the hitch bolt and the only thing it does is keep the hitch on. The actual axel bolt is hollow in the center with the hitch bolt going through it. Remove it with no fear of anything else falling off. As nautibrit said, be careful to not disturb speed sensor or brake line..... Jim
    Semper Fi
    Mar 2013
    Quote Originally Posted by Tango View Post
    The bolt used on the hitch goes through the axel so no worries about the wheel moving. As George stated you may need to persuade it to move. I use a small piece of 2x4 and a mallet to work it off making sure that the brake and sensor lines are clear.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Apr 2012
    Florida
    So the bolt is removed and goes with the hitch. Not needed to reinstall. Just want to make sure. Thanks all. Tom
    Nov 2018
    Waynesboro, PA
    Yes the bolt, nut and washers are part of the hitch. After the hitch is off then there were little plastic caps that covered the axle holes. But you may not have them now so don't worry about that.
    My Spyder
    2012 RTL , Brown
    Bossier LoUiSiAna
    Probably lil late but here: Pierre shows how to put his on , just do in reverse order
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Apr 2012
    Florida
    Thanks everyone. It and the module are off and ready for sale. Tom
