Results 1 to 9 of 9
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Default OEM Spyder Hitch Ball
    Has anyone out there tried to remove the hitch ball that comes mounted on the OEM Spyder Hitch?
    I have tried everything including a 4 foot breaker bar on the nut and the ball both and ended up bending one of the Snap-On breaker bars.
    Any help would be appreciated.
    2022 RT Limited , Silver w/ Black and Purple accents
    Nov 2018
    Waynesboro, PA
    With the hitch off I heated the ball put it in a vice and removed the bolt.
    My Spyder
    2012 RTL , Brown
    Quote Originally Posted by campermac View Post
    This might help. https://www.spyderlovers.com/forums/...brp+hitch+ball
    Bossier LoUiSiAna
    IMG_5741.jpg Wanted to swap to one of those interchangeable types where you have 1 stud & can swap the ball size with no tools
    the hitch to low to ground to get my impact to fit, went by Harley shop tech got it off for free Was surprised to see the amount of rust inside & no lock tight. Applied anti-seize appropriately when put back on. FYI the oem hitch hole too small to fit the interchangeable type not sure the diameter sorry. Don't get hernia attempting at that low position
    Jan 2015
    southern WI
    If you get it off, drill the hole out and use whatever you please. Yet another reason to go with aftermarket.
    2016 RTS , Pearl White
    Bossier LoUiSiAna
    Update any LUCK??
    Feb 2012
    Spring City,Utah
    With rust who needs locktite.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2015
    Etters PA
    took the hitch off the bike, clamped the ball in a vise, added a little bit of heat, used a 36" breaker bar and off it came.
    Persistence wins again!!
