Results 1 to 13 of 13
    Dec 2013
    SF Bay Area
    Default FOBO 'disabled' question
    This time every year I have to replace the batteries even though they look good. Usually not a problem.
    This time, replaced the battery on the rear tire and all is good. However, both the Front Left & Front Right say they are disabled. I can't figure out how to enable via the FOBO User Guide.
    Anyone have this issue or instructions on how to enable before I fix it with a hammer
    2014 RT-SE6
    Akrapovic Sport Touring 3C Silencer
    High Mount Third Brake Light
    Kuryakyn Black ISO Motorcycle Grips
    LaMonster Spyderdock
    LED’s everywhere!
    Russell Day-Long w/ Backrest
    Seal Floorboards
    Spyderpops Bump Skid
    Spyderpops KOTT Grill (Keep Out The Trash)
    Squared Away Alignment
    Riding taught me why dogs stick their heads out the window!
    Aug 2013
    SF Bay Area
    My first thought is to replace the batteries in them and that should enable them. Try removing them one at a time then wait 8 seconds then put back on and touch the phone to it. This is instruction when updating the firmware. Holding your finger on the sensor in the phone pulls up a menu and see what choices you have.
    2021 F3 Ltd , Magna Red
    Dec 2013
    SF Bay Area
    Yeah, I tried that but got something like 'operation unsuccessful.' Thanks though. Are you a member of SRASF?
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
    Aug 2013
    SF Bay Area
    No I never got into SRA although I'm a Life AMA, GWRRA member. I've done SRA runs. I'm closer to San Jose. Knew a few SJ Dons.
    Dec 2013
    SF Bay Area
    Sent you a PM.
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    I just went thru this on mine. 2 of them just stopped working out of the blue. Replaced batteries etc. turns out, the firmware was far enough outdated it no longer worked with the Android version on my Note 8. AND, get this! You can ONLY update firmware if you have an Apple device!!!!!!!!!!!! The option for firmware only exists in that version of the app! SO STOOPID!
    Luckily I had an iPod Touch w/ Wifi and got the firmware updated, then was able to enable the sensors. You have to choose the disable/enable option in the menu at the upper right when in the app. It'll tell you to press and hold on the sensor you want to enable for 5secs. It'll then walk you thru the process. Makes sure you have the sensor removed from the valve stem before starting the procedure.
    Chuck
    Dec 2013
    SF Bay Area
    Quote Originally Posted by hypurone View Post
    Appreciate that.......might take you up on that. At this point, I contacted FOBO via email. I didn't want to call as it seems like they are in Malaysia?They surprisingly got right back to me. They asked a few questions and said they will get back to me soon. We'll see.......
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
    Nov 2018
    St Pete Beach
    Does anyone know if the Fobo 2 sensors are now working with BRP Connect? Thanks
    2018 RT , Asphalt Grey
    Northern Kalifornia
    Quote Originally Posted by martiniman View Post
    I have the exact same problem. Please post the answer you get from FOBO so we can all fix our FOBO problems.
    Northern Kalifornia
    Default Solved...........
    "Makes sure you have the sensor removed from the valve stem before starting the procedure." That was the trick to getting the FOBO's back functioning again.
    Thanks hypurone!
    Feb 2020
    Ohio
    Quote Originally Posted by McClendons View Post
    I just asked the Fobo people this exact question and I got a reply that said they have released the updated app to BRP for them to do compatibility testing on. So, progress is being made. No ETA though...
    Apr 2019
    Clinton, MS
    Both FOBO and BRP Connect released app updates today.
    FOBO:
    What's fixed:
    ...Misc bugs
    ...Minor UI bugs
    What's pending:
    ...BRP Connect integration
    BRP Connect:
    ...Fixed issues
    ...iOS 13 support
    At least FOBO thinks enuff about it to call it out in the release notes.
    Sep 2018
    Sneedville, TN
    I never could keep the FOBO working for any length of time. I got tired of the aggravation and removed them. They're in a drawer in my garage. Maybe I'll check the firmware updates and try them again.
    2018 Spyder RT Limited
    Asphalt Gray
    Can Am Passenger Armrests
    Can Am Comfort Seat
    Spyder Accessories Floating Footpegs
    Utopia Driver Backrest
    Bajaron Sway Bar
    Sena 20s Bluetooth
    Lidlocks Helmet Holders
    F4 Tall and Wide Tinted Windshield
    Fobo Tire Monitor
    Lamonster Spyderdock Cell Phone Holder
    Sheepskin Seat Cover
    Drink2Go Cup Holders
    Magic Mirror
    Can Am Trailer Hitch
    Missing Belt Guard
    Wish List - LED Headlights and Fog lights
