Results 1 to 5 of 5
    Aug 2018
    Santa Ana, Ca
    Default 2016 Spyder RT LTD front shock top bolt install
    I found a better way to install the top bolt by using this tool for installing bolts in auto frames for trailer hitches:
    CURT 58390 18-Inch Trailer Hitch Fish Wire for 3/8-Inch Diameter Bolts bought on Amazon
    Aug 2007
    Greeneville, TN
    Interesting! Should be a help to many.
    Quote Originally Posted by Dean8 View Post
    That could work …. but for way less money, just paper tape the nut to closed end of a combo wrench ……. Mike
    Nov 2018
    Claremore, Ok.
    Sorry to steal this from Curt, but just solder the wire to the end of a Heli-coil for whatever size bolt is needed for any needed application.
    I needed to get at those top bolts when I installed Baja Ron's Spring Adjusters and couldn't get at them(wire Bundles in the way), so I just took the whole frunk off. Found lotsa interesting things under there that needed attention. Easy to get off BTW.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Aug 2018
    Santa Ana, Ca
    Great ideas
