Results 1 to 12 of 12
    Active Member bcraig's Avatar
    Grove City, OH USA
    Default Bajaron sway bar links spacers?
    Just ordered the Bajaron sway bar for my 2019 Spyder RT Ltd from Lamonster. I noticed in the picture of the product it appears they now use spacers for links. However, the instructions I downloaded shows only the use of the bolts with no spacers. Nothing in the instruction address using spacers. Does the Bajaron sway bar now require spacers for the end links?
    IIRC there has been some recent discussion of how to easily fit the spacers, but I reckon your best bet to find out for sure would be to PM Baja Ron.... Or if you like, you could check out his 'Sponsor Page' (see below) & the contact details there & you could give him a call direct!
    https://www.spyderlovers.com/forums/...rs-amp-Helmets
    Active Member krakum1967's Avatar
    Dec 2019
    Western Colorado
    if you email him, or contact him here, he will get back.....great service....
    Kraig B. Kumlin, M.M., M.C.P. (Retired)
    Only Two States Left to Visit on MC or Trike, RI and CT
    2012 RS-S , Baja Ron Plug Wire Kit and NGK Iridium Plugs Grey and Black
    Grove City, OH USA
    Quote Originally Posted by krakum1967 View Post
    I just PM him and Lamonster. Thanks for the suggestion.
    Help is on the way. Just need an email address to send it.
    Grove City, OH USA
    Thanks. I PM you my email
    Grove City, OH USA
    Received sway bar about noon today. Finished install about 4:00. Took my time and a lot of coffee. Super glue did the trick with the spacers. Everything went smoothly per instructions. Too wet and rainy to test, but I'm sure it will be an improvement.
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    Question.
    I think I have the ability to install it.But I don't think I could get it safely 24 inches high to remove it.Frustrated
    Quote Originally Posted by sgerksinwi View Post
    Question.
    The 24" recommendation is from the sway bar frame channel to the ground. Not the total amount of lift needed as you start with 4" or so of ground clearance to that frame member. Then, if you leave the rear wheel on the ground and lift to an angle. That also reduces the needed lift a few more inches. And you only need this amount of lift for the actual old bar removal and new bar insertion. Everything before and after this 5 minute process can be done with just enough lift to get under the Spyder.
    Lifting isn't the only option. Some have used 2 motorcycle ramps off the back of their truck. Others have used a hole (stairway) in their basement. One customer had a man-hole in their driveway. They pulled the cover and rolled the Spyder over the hole to do the bar swap.
    I am not telling you, you SHOULD do it. Just that, done properly. It isn't as bad as some might imagine.
    Jun 2019
    Wisconsin
    I will have to take a closer look but thank you very much
    If you would like a copy of the installation instructions. Just send an email to fyredad@hotmail.com
    I'll email you a PDF copy.
    Aug 2012
    Central Coast, CA
    I used some truck jack stands under the front A arms for safety and a floor jack on the frame for lifting and it worked fine.
    2020 RTL SE6
