Results 1 to 20 of 20
Thread: Front tire size
    Dec 2011
    Bonita Springs, Florida
    Default Front tire size
    I have a 2014 RT that has 165/55/R15 tires. Is there any clearance problem going with 175/55/R15 replacements.
    Mar 2013
    Most don't, but I did on my 2014RT. Normal driving no issue, but when I pushed it hard in corners I would get rubbing on the lower inside fender.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Quote Originally Posted by Alberts46 View Post
    Vredestein Quatrac 5 tire is the best currently being sold ….. they have a few sizes that will fit and everyone on this forum loves them ….. Mike
    Dec 2011
    Mike, thank you. That is the tire I was told to purchase from Tire Rack but my installer was concerned they would rub as mentioned in the first response. I was hoping someone else that has that particular size and make can confirm no issue. Tire Rack did not have the 165.
    Try these two sellers, others have bought their Q-5's from them …. Simple tire and or Vulcan tire …… Mike ....PS the 175/55-5 will fit , but the 165 is usually less money...… the Vredestein Q-5 already has way more traction then the Nanny will allow …. I bought the 165 for just that reason ….. Mike
    Aug 2019
    Stoughton, WI
    165/60R15 shows in stock status. I bought a pair .. https://www.tirerack.com/tires/tires...omCompare1=yes
    2022 RT Sea To Sky
    Sebring, FL
    If you decide to go with the larger size, give us your report.
    Mar 2018
    north georgia
    i have the Q5's in 175' on my 17 RT and have a little over 5,000 miles with no issues and alot of twisty miles here in No. Georgia what a difference it made in handling absolutely on rails
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Whitedog43, What air are you running at?
    Can Am 2013 RTL SE5
    Default Larger size tire
    Will the traction increase possibly -( repeat possibly ) however it will be so Slight only special instruments will be able to tell ….. and lateral traction is very controlled by the Nanny ….. here's how the Nanny works …. lets say you could pull 1- " G " on a 165 width tire and 1.2 G's with a 175 tire ….. the Nanny will only let you pull 1 G …. I'm NOT guessing this …...good luck …. Mike
    Dec 2011
    One last question, the tires from tire rack are 165/65, original tires 165/55, any concern with 65 vs 55.
    NO , 65 vs. 55 is the aspect ratio ( ie the height of the tire at the sidewall ) and will have little or no meaning considering the low weight of the Spyder front end …… Mike
    Dec 2011
    Mike, thank you ordering them.
    Please keep us posted on what you discover about it's handling and ride feel ( fellow members here love to hear about actual owner's opinions ) ….. My self and Peter A. recommend a lower PSI for Auto tires ie about 17 front and 18 rear ….. good luck ….. Mike
    Mar 2018
    north georgia
    sorry for being so late with a reply, fronts 17, rear 18/19
    Dec 2016
    Blueknight911: The height of the tire sidewall does have a mineute affect on the caster angle of the steering. It's slight but it is a little.
    Can Am 2013 RTL SE5
    Quote Originally Posted by wingit3611 View Post
    Yes and I said " little or no meaning " …… imho even at 200 + plus MPH, the change in caster angle, wouldn't give me any concern as to the handling difference..... there used to be joke decades ago about the Princess who was upset about the Pea under Her pile of mattresses …. I'm not that person ….. However if your post was for a " gotcha " moment - you succeeded ( by a hair ) …... …… Mike
    Dec 2016
    No gotcha, Spyder's just have a very sensitive steering. Every little thing seems to effect them.
    Can Am 2013 RTL SE5
    May 2013
    Edmonton Alberta, Canada
    I have Continental ContiProContact in 175-55-15 on my 2014 RT-Ltd and they fit like a glove and I have no complaints with he ride or handling!
    2014 RT-Ltd , Cognac
    I have found thru testing and other knowledge basis - that front tires, that are over-inflated based on the weight they carry will be " Twitchy "....this generally doesn't occur with Auto's & Trucks because the Max on the tires isn't enough to make it noticeable ….. Mike
