Results 1 to 5 of 5
Thread: Sway bar links
Hybrid View
    Feb 2019
    England
    Default Sway bar links
    Hi all . Just fitted spyders pops end links to Ryker. Hardest job is getting the little spacers on , through bolt/ spacer on / through link then the hard bit spacer on ( not much room) push through frame , tighten all up . I used thin long nose plyers/ torch and struggled under bike I found it hard to do , but got there in the end. Regards Nico 75
    INDIANA, USA
    Default New Links
    Thanks for your Tip......
    ENJOY YOUR LIFE WITH A SPYDER
    An easier way is to simply super-glue the spacers to the spherical ball ends. Only takes a moment and then you can simply slide the entire assembly into place and insert the bolt.
    Feb 2019
    England
    Thanks for BajaRon that will help others , I just like struggling regards Nico 75
    Quote Originally Posted by Nico75 View Post
    All of my products come complete. Struggles are provided at no additional cost!
