Spring loaded trunk
Buy a 1/4" or 3/8" spring nut. You can get one at any Lowes, Home Depot, or any wholesale electrical supply house. They cost a buck, maybe.
Blurry pictures, sorry.
Next, remove the spring from the cast nut.
Place sprint over latch stem, and seat with ordinary "non hardening" silicone. There is no lateral pressure to move the spring so silicone will hold it just fine.
I'd put this on EBAY, but it'd be like selling money making ideas...a ripoff.
Happy Owner
Chances are the referenced post is positive in nature, may result in a solution, alteration, modification, or highlights an extraordinary event or ride, that's worth posting.
Rando where did...
Where did you get that particular shaped spring?
"The Ancient Warrior"
Ken krb1945 "Happy Owner"
USN DAV 100% 'er
Proud grandfather of a former United States Marine
1 2008 SM5 PE 548
1 2008 SM5, 1 2009 SE5
2008 GL1800
It's a compression spring. I just bent the end to make it look like that. Works great!
Before anyone says anything, I need to take a picture, but I put a couple of springs on my on either side of the trunk latch. Meant drilling a couple of holes, but it works well. I tried just one and decided to add the second to get it pop open a bit easier.
Humm I would love to do this to my trunk. Such a simple idea to solve such an annoying little thing as popping the trunk. I went looking at HD for a spring and could not find one. Anyone point me in the right direction?
Mole
Motorbike Professor
Mole
ACE Hardware, ACO, or any other good hardware store. They should have a #155 spring in their spring assortment.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Very Helpful Member
Mole
PM me with your address and I'll send you one. Once you get it and verify it works for you, you can reimburse me for the postage. FYI, the last batch of these I sent out cost about $1.25 to mail.
Former Happy Spyder Owner
Just decided it was time to move onto other things.
bjt -PM sent!
Thanks!
Mole
