Results 1 to 9 of 9
    Aug 2018
    Port Orchard WA
    Default GS LED Headlight Conversion Help!
    Does anyone know what H7 conversion headlights work with my 2008 GS? I got some off of amazon and got the Mercedes type clips and still cant seem to get it to work.
    Please let me know what LED headlights work.
    I posted this in the technical forum but I haven't gotten any responses back.
    Mar 2008
    Hesston, PA
    I know the GS/RS Headlights can be a challenge to up grade...BRP offered a HID conversion for a lot of money (1000.00 plus)...Some have recently found the BRP HID's for around $100.00 or so...New old stock dealers are trying to unload...
    I'v been dealing with "Headlight Revolution"...This outfit is VERY KNOWLEDGEABLE & HELPFUL...They are a USA company dedicated to customer service...Call and talk to their representative and explain your problem with the clip style mounting system they used on the GS/RS and MAYBE they can help...Please report back on your outcome...larryd
    Quote Originally Posted by larryd View Post
    Had a pair of the old HID's on my 08 GS. $1,500 installed. I remember saying something like, $750 per light....
    Danbury Connecticut
    What's not working ?? Is it that they won't turn on ??
    Incandescent lamps work by putting power to the filament and heating it up. The direction of the power flow is irrelevant.
    By contrast, the HID and LED lights are electronic circuits.
    Specifically, you have to connect them in the right configuration. Plus power needs to go to the plus side of the bulb circuit, and the same with the minus side.
    In other words, to quote Montgomery Scott "Captain, we need to reverse the polarity to save the ship"
    Seriously, you may need to reverse the wiring to the bulb. I believe you can do that by moving the wires in the plug to the bulb.
    I had to do that when I switched to HID lights on my 2014 RT, and later when I switched to LED bulbs.
    Remove the wires as shown in the picture and just reverse them
    IBA #47122
    2020 RT Limited Asphalt Grey
    Aug 2018
    Port Orchard WA
    Heck. I’m just having a hard time getting them installed in the bike. The brackets are hitting the back of the led housing for the units that I bought
    This issue has come in the past couple of years ….. and a solution to the " securing clip " was found …. do an advanced search to locate the Threads / posts …… good luck …. Mike
    Jan 2019
    Hunter Valley NSW Australia
    Check out JW Speaker H7 - the new type.
    These bulbs are LED and are the same size as an original Halogen globe. The Driver and CanBus adapter are built into the bulb housing.
    I had the same problem with my wifes car, the ones I purchased were the original style LED with a large external Driver, and when fitted I coudn't fit the rear headlight housing back on. I also would have had to modify the housing to accommodate the Driver. On top of this when I installed the original style LED, they'd remain on for 30 seconds then shut off - telling me they needed the CanBus adapter.
    It was a fluke that the Auto Part Shop I bought the JW Speaker original style LED's from didn't have any CanBus adapters in stock, so I got a refund and went to another Auto Part Shop. They showed me the newer LED bulbs from JW Speaker and could not believe it took manufacturers this long to product a LED bulb that fits the same as a Halogen.
    2017 RTL , White
    Jan 2019
    Alliston Ontario
    I posted a full tutorial on exactly how to do this. Done it on a few GS spyders. Look up my threads! Cheers Dave
    Jan 2019
    Alliston Ontario
    https://www.spyderlovers.com/forums/...e-DIY-required
    Full Tutorial how to do it on a GS
