Results 1 to 11 of 11
    Greenville Tx
    Default Is it possible to change a Limited into a Touring power train?
    By swapping rear Sprocket, Belt and BUDS setting designation to a touring model? Asking for a friend.
    2017 F3 Limited
    Quote Originally Posted by AY4B View Post
    I don't have the expertise to answer about what could be done with ECU, but I don't think BUDS could do it ….. as far as the Sprocket is concerned, I doubt you find a smaller Sprocket & belt combination that would give you enough to warrant the expense and effort ….. jmho … good luck to anyone considering this ….. mike
    Nov 2012
    North Las Vegas, NV
    I think a few have tried this and found no joy.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Mar 2008
    Hesston, PA
    Its my understanding that all F3 can be easily programmed to 79T or 89T rear sprocket sizes by any dealer...
    jc from Tx. hopefully reads this and can advise better than me...
    larryd
    That modification (post #1) is above many of our pay grades. I have been driving "touring" bikes all my life (Kawasaki Voyager, Yamaha Venture,) among others configured in "touring" mode. Add to that three RT's, and now a F3L, and I am still happy with the touring aspects of the Spyder.
    For me, no additional touring upgrades needed.
    Houston
    Quote Originally Posted by larryd View Post
    larryd
    The setting is there in BUDS but....
    Changing it seems to knock several other items out of alignment in VSS and the nanny pitches a fit. I know two folks that have tried this sprocket change and both failed with the same results. I know Monster was working on it but have never heard of anyone completing the changeover.
    I do think its possible using BUDS but one would have to know all the other VSS settings bits that need to be changed along with the sprocket size. BRP has not seen fit to drop anyone a anonymous note with the magic juju contained.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    By what I've read...the RT...cannot be changed..at least for now...since you indicated that the setting is there in Buds..has any body tried to do it on a F3 platform..an RT And RT are different platforms...it would be interesting to see someone try it.
    Oct 2017
    covina california
    By what I've read...the RT...cannot be changed..at least for now...since you indicated that the setting is there in Buds..has any body tried to do it on a F3 platform..an RT And F3 are different platforms...it would be interesting to see someone try it.
    Greenville Tx
    Im assuming James was referring to someone trying it on a F3 Limited. He said that monster is working on it. I like your suggestion of doing it and then getting the flash based on a F3T. Maybe for kicks I can call Wick-it and see if they have any info on that. With the new module coming out, It may be possible to get the stage one flash but still be able to make the change to a F3T if they ever get it figured out.
    2017 F3 Limited
    Oct 2017
    covina california
    Yes indeed..
    Mar 2008
    Hesston, PA
    Several years ago I THINK I remember reading someone was attempting to do that change on their F3 (79T to 89T or 89T to 79T) and the dealer was having difficulty with the programming change and BRP Care posted on here to have that dealer contact them...
