K& N CVT side
Hi all a few tips on fitting K& N to CVT side A long , very long ext on 8mm skt for bottom bolt , I took out the 4 easy bolts first , then bottom bolt , fitted K& N ( easy bit) I then dropped one bolt down somewhere on to frame but my wife spotted it and little fingers go it out . Then when trying again Dropped it again thi time further on to frame but I could see it Long flexible magnet carefully pulled it out . So I put a blob of grease on bolt head to hold it in skt and fitted the hidden bottom bolt Yes I struggled but it won't be done again . Last job I sprayed a bit of WD40 on side holders to ease the cover back on job done ( took me longer than you to read this haha
Regards Nico 75
Nico75,
What was the part number for the K&N?
Thanks!
Hi cjc96ryker. K& N partn is CM 9910 ( cost me 75£ for two ). Regards Nico 75
You can take off the air intake on the cvt side and expose all bolts for easy on off. Simple.
Hi RykerUSA yes I know , but the bottom bolt is still hard to remove / replace I dropped it twice. Regards Nico 75
Just replaced both my filters from bajaron
I tapped an 8mm socket (1/4" drive) onto a long 6mm Allen wrench, using the "ball nose" end of the wrench. This works real good. I got this idea from one of you fellow Ryker riders out there. THANKS!
