Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
  1. #26
    Dec 2015
    Oakley Utah
    You can buy either the fuel filter assembly that includes two Oetiker Clamps, PN 219800056, $16.49, from BRP or Cheap Cycle parts, both online, but you must have Oetiker Clamp pliers to properly install.
    They look like regular PEX plumbing clamps. Anything different about Oetiker clamps / pliers?
    https://www.youtube.com/watch?v=W1qTw8OmbMA
    https://www.homedepot.com/p/The-Plum...B&gclsrc=aw.ds
    2014 RTL Platinum
  2. #27
    Jul 2014
    Mint Hill, NC
    These are the pliers I have, they have both front and side jaws. My house doesn't have any PEX stuff in it so I didn't know anything about the system, just bought the pliers the first time I changed fuel filter. Got 'em from Amazon, $30. The Oetiker clamps from BRP are each individually sized for the particular tubing by PN. Got my first parts from local Spyder dealership that was sold. Have switched to Cheap Cycle Parts where I can because nearest Can-Am dealer is now a Ride Now facility 25 miles away whose parts department I am unimpressed with; they frequently don't have the simple stuff - poor inventory management.
    https://chadstoolbox.com/knipex-10-9...kaAtKIEALw_wcB
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
  3. #28
    Idaho
    The PEX clamps are Oetiker clamps, or a copy. Oetiker is a brand name. There are also similar clamps used for poly pipe, like irrigation, but use the same pliers. Go the Lowes or Home Depot and take a look at them.
    2014 Copper RTS
  4. #29
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Or just replace with FI rated band clamps.
    2020 RTL SE6
  5. #30
    Dec 2015
    Oakley Utah
    Quote Originally Posted by KX5062 View Post
    What's that?
    2014 RTL Platinum
  6. #31
    Dec 2015
    Oakley Utah
    I already have the PEX tools and clamps, but ordered the Knipex from HD for $20 anyway. I like the side jaw feature for tight spots.
    2014 RTL Platinum
  7. #32
    Jul 2014
    Mint Hill, NC
    FI rated band clamps are solid and don't cut into the fuel line as the screw is tightened. You will find the side jaws of the Knipex pliers very helpful on the Spyder.
    Cognac 2014 RT-S
  8. #33
    Idaho
    There have been any number of times I could have used a side jaw crimper. I didn't even know they existed! One thing for sure when you're crimping the ring on a 3/4" or 1" PEX - your grip had better be strong! Many times I've had to put one handle against something solid so I push harder on the other one.
    2014 Copper RTS
  9. #34
    Dec 2015
    Oakley Utah
    The PEX crimpers I use have a ratcheting feature because of the force required to crimp that steel. I'm thinking the Oetiker clamps must be of softer material since the pliers have little mechanical leverage.
    2014 RTL Platinum
