Page 1 of 8 12345 ... LastLast
Results 1 to 25 of 198
    Aug 2007
    Greeneville, TN
    Default New Kenda Tires!
    This is all I know. Didn't have time to look any further.
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    I have one in my garage, the rear tire. Kenda Kanine. Paid $96 including shipping from MotoSports.... waiting for the weather to warm up so I can have the dealer install. I guess I'll be the "test case". Still in the dark on what inflation pressure to use. I'll post the sidewall information from the tire when I get back in town. After I post the info, maybe someone can give me some recommendations on proper inflation, otherwise I'm going with 28 psi.
    Nov 2017
    San Francisco Bay area
    So I want to take this as good news that will eliminate the hassle of getting a dealer to put on a car tire.
    Questions I have, is Kenda known for making a decent tire of any type (if no it doesn't mean this one isn't good, just not a great indicator) and since it "looks" more car tire spec size does that meant dealers may be more forgiving about putting on a car tire that is rated for the rim than they are now?
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    2015 RTL , Yes Pearl White
    Jul 2017
    Huntsville Alabama
    Quote Originally Posted by LeftCoast View Post
    I kinda doubt it. I do remember that the sidewall on my Kenda Kanine says "For Motorcycle Use Only". My dealer asked if that was on there and I said yes. He said, "OK, then I can install it". All the dealers in this neck of the woods won't substitute car tires on the Spyder.
    Nov 2019
    Kansas
    I may just buy the full set and see how they do.
    May 2009
    Connecticut
    https://www.motosport.com/product/?a...1-Y001&variant[KDAA009]=KDAA009-X001-Y001&variant[KDAA00A]=KDAA00A-X001-Y001
    $230 for All 3 isn't bad if their decent?
    Sea Doo GTI-SE 90 Jet Ski!!
    Bossier LoUiSiAna
    Quote Originally Posted by Sarge707 View Post
    big “IF” bout the only Kenda tire that might get good mileage B5EFFA7B-7400-4F5E-87B0-5CF9F0FDB89D.jpg
    sorry didn’t even see if was on front & back, or test ride.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Mar 2013
    Marion, Arkansas
    As you can see not much information out there yet.
    Product Details
    Kenda KR20 Kanine Tire
    •Longer lasting than stock
    •Better performance than automotive replacements
    •Designed to work with ABS and TCS
    •Blackwall
    •Tubeless (TL)
    •H-rated for speeds up to 130 mph
    Specs for Kenda KR20 Kanine Tire
    Tire Construction
    Radial
    Sidewall
    Blackwall
    Units
    Each
    Tire Classification
    Cruiser
    Speed Rating
    H(130 MPH)
    Type
    Tubeless
    Material - Tread
    Steel
    Material - Sidewall
    Polyester
    Sidewall Plies
    Inflation Pressure
    44 psi
    Material - Tread
    Polyester
    Directional Arrow
    No
    Tread Plies
    3
    Front Tire Specifications
    Brand:
    Kenda
    Part #:
    Mfg #:
    Sidewall
    Bias / Radial
    Speed Rating
    Load Rating
    Ply Rating
    Tube / Tubeless
    Rim Size
    Tire Size
    Front
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jul 2017
    Huntsville Alabama
    Quote Originally Posted by Ex-Rocket View Post
    Product Details
    •Blackwall
    •Tubeless (TL)
    Tire Construction
    Radial
    Sidewall
    Blackwall
    Units
    Each
    Tire Classification
    Cruiser
    Speed Rating
    H(130 MPH)
    Type
    Tubeless
    Material - Tread
    Steel
    Material - Sidewall
    Polyester
    Sidewall Plies
    Inflation Pressure
    44 psi
    Material - Tread
    Polyester
    Directional Arrow
    No
    Tread Plies
    3
    Brand:
    Kenda
    Part #:
    Mfg #:
    Sidewall
    Bias / Radial
    Speed Rating
    Load Rating
    Ply Rating
    Tube / Tubeless
    Rim Size
    Tire Size
    Front
    Just to clarify, I know mine has a directional arrow and they are clearly directional tires. Also the 44 psi is stated as Max pressure on the sidewall, not recommended inflation pressure. I'll post verbatim info from the sidewall when I get back in town.
    Jan 2019
    Toowoomba Qld Australia
    Interesting how they make specific reference to "passenger car replacements" and being better than stock.
    "Greater mileage than stock, better handling than passenger car replacements."
    2014 ST-S SE5 Cognac
    2014 ST-S , Cognac
    Dec 2013
    Quote Originally Posted by HankD View Post
    Mind you, if it says this on the sidewall, then these tires are gonna be ILLEGAL for anyone to fit on an OE Spec Spyder rim here in Aust, cos our Spyders have 'J' type CAR rims & it's the legal responsibility of both the vehicle operator and the tire fitter to ensure that tires labelled 'MC' or 'Motorcycle Use Only' ARE NOT used on &/or fitted onto CAR rims & vice versa!!
    However, all that aside, Kenda have been known to make some pretty good tires, but that does seem to be fairly dependent upon which factory they come out of & what their intended use is..... I guess we'll hafta wait & see. AFAIK, these tires aren't available in Aust (yet?) & from what I've been able to find out, there aren't any of the usual tire importers even considering them for Aust..... yet?!?
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Nov 2019
    Kansas
    I wanted to replace the front two tires anyway, so I bought the front set of these new kendas. I guess I will find out how good they are.
    $131.00 shipped for both.
    Jul 2017
    Huntsville Alabama
    Anyone know offhand what the Max Inflation Pressure on the old OEM Kenda's is (Rear Tire)? I mean max pressure listed on the tire sidewall, not what the Spyder Owners Manual recommends. I just wanted to compare to the new Kanine. Thanks.
    Oct 2016
    Sebring, FL
    As someone mentioned, $230 for 3 is a good price, plus dealers can do the install without all the hassle. Maybe Kenda has it right..
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    It says:
    Max load 400kg(882lbs)at max inflation pressure 30psi
    standard rim 7.0J
    orig Kenda rear tyre
    pres ride
    2014 RT-S
    bike is WIP
    bike has endured elect spike (was jump started incorrectly)
    still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
    Jul 2017
    Huntsville Alabama
    Quote Originally Posted by merlot View Post
    It says:
    standard rim 7.0J
    Thanks!
    So, the new Kenda Kanine rear tire is max pressure of 44 psi at 882 lbs. max load vs. the old OEM Kenda rear tire of 30 psi max pressure at 882 lbs. max load. The Can Am Spyder Manual for the old rear tire recommends 27-30 psi normal inflation pressure (near the max for that tire).
    Just doing a basic scale-up using the max pressures would lead me to believe that the normal inflation pressure for the new Kenda Kanine tire should be about 40 psi? That seems kinda high. Any tire guru's care to chime in? I'm certainly no tire expert.
    Until the Actual specs are posted for this tire …. I will reserve judgement ….. guessing about this or anything else is a big mistake …… Mike
    Jul 2017
    Huntsville Alabama
    Ok, I got my "better half" to read off the information from the Kanine rear tire I have in the garage. Here it is (it's all Greek to me):
    005A (circled)
    DOT 1K3 Max Load 400 kg (882 lbs.) AT
    Max Press 300 kPa (44psi) COLD
    For Special Motorcycle Use Only
    Made in Taiwan
    E4 (circled) 75R-0014862
    Radial Tubeless
    Standard Rim 7.0J
    Tread 3 Plies (1 polyester + 2 steel)
    Sidewall 1 Ply (1 polyester)
    225/50R15 M/C 76H
    Make any sense to anyone?
    Dec 2013
    ......Just doing a basic scale-up using the max pressures would lead me to believe that the normal inflation pressure for the new Kenda Kanine tire should be about 40 psi? That seems kinda high. Any tire guru's care to chime in? I'm certainly no tire expert.
    You'd need to include the static load your 'fully loaded with ryder/pillion aboard' Spyder is imposing on that rear tire to even roughly calculate the static inflation pressure required, and then there's all the other variables that might come into play....
    Have you weighed your loaded Spyder with ryder/pillion aboard lately? Any place with a weigh-bridge should be able to help (garden centre, wood-lot, public weigh-bridge?!?) And weigh the front end & the rear separately, making sure the Spyder is level & loaded normally when you do it.
    Dec 2013
    005A (circled)
    Made in Taiwan
    Radial Tubeless
    Standard Rim 7.0J
    225/50R15 M/C 76H
    Yep, the bolded & underlined bit ^^ makes the Kenda Kanines an ILLEGAL fitting choice for our OE Spec 'J' Type CAR (& Spyder) rims, at least here in Australia anyway!
    Nov 2017
    But it's fun!
    Baja Ron Sway Bar
    Strobe Brake Light
    Jul 2017
    Huntsville Alabama
    Peter,
    Using some research (done by you) previously on weight distribution, I think that a 2017 Spyder RTS with a normal load and a 175 lb rider (me) should weigh a total of about 1250 lbs. Using an estimate from your research of about 45% of that weight on the rear wheel, that puts the rear wheel load at about 560 lbs. With a second passenger, it would be up to 625 lbs on the rear tire. Given those (estimates).....what inflation pressure would you use for the Kenda Kanine rear tire given the specs I listed previously?
    Thanks!
    Dec 2013
    Bearing in mind that the ryder/pillion weight isn't all carried by the rear tire (because of the frame & suspension/swing arm/shock design, an increasing percentage of that weight, said % dependent upon the load on the rear frame, gets transferred forward & onto the front tires) so I'd be a little bit surprised if the rear of your Spyder actually got that high Hank. But IF the load on the rear tire is really that close to 300kgs, then given what we know so far, a rough 'educated guess' for your ideal pressure in that tire would be somewhere in the vicinity of 28-32 psi - BUT and please note well... that is pretty a rough guesstimate at this stage, because just like Mike said earlier, until the ACTUAL specs on these tires are made available, we really don't know enough about them yet....
    Jul 2017
    Huntsville Alabama
    Understood, I'm just looking for a place to START the process. Can Am and Kenda have been ZERO help with this, and I need to tell the dealer/installer..."Fill it up to XX psi". 28-32 isn't that much different than the stock OEM Kenda recommendations in the Owners Manual, but even with the increased "max" psi rating of the new Kanine I would feel safer starting off with a pressure that won't blow my tire up on the 80mile trip home from the dealer. I'll start with 30 psi/single rider and see how it goes Thanks for the help.
    PS. What "actual" specs are you looking for. Something that I didn't list on the sidewall markings?
    Idaho
    These tires were discussed in another thread just about a week or 2 ago. Don't know offhand if there was different info in that thread or if most all the pertinent info is repeated below. Sorry, I'm too disinterested to bother to find the other thread!
    2014 Copper RTS
