Results 1 to 8 of 8
Thread: Y Connector
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    Default Y Connector
    I recently purchased a used BRP OEM trailer hitch and it included 2/3rds of the wiring harness.
    I have the taillight converter, BRP part# 710003903 and the trailer pigtail BRP# 710003272
    What's missing is the Y connector for connecting to the bikes wiring harness to make this a true "plug n play"
    Can someone supply the correct BRP part # for this Y connector and is the dealer the only source for it?
    Came off a 2016 RT and going on a 2017 RT
    As always, Thanks
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Nov 2018
    Waynesboro, PA
    Not sure if this is what you are looking for http://store.valueaccessories.net/Tr...sSpyderRT.aspx
    My Spyder
    2012 RTL , Brown
    Oct 2017
    Looking for the BRP OEM Y connector part # I have the other parts
    Gary
    1987 BMW K75s
    SoFlo
    Quote Originally Posted by Garf View Post
    I do not have time to look, but if you go to the Spyderlovers homepage, there is a link to the Can Am instructions for many of the accessories. First find the part number of the entire trailer kit for your bike, then search the link for the instructions. The instruction sheet will give applicable part numbers for items in the kit. Whether they sell the harness outside of the kit is another hurdle. All the best with it.
    Jul 2011
    Mitchell, Ontario, Canada
    They are available as a separate item. Look in the accessories catalog 2018 or 2019 under trailer. I think it is called module harness. Look for the one that matches your year and model.
    Oct 2017
    Found it!
    The Y connector alone appears to be #219400893 This is for the 2010-2017 RT
    Now if I can just get BRP's website to play nice....
    Thanks to all
    Gary
    1987 BMW K75s
    Found it!
    Thanks to all
    The Y connector when I made my harness back in 2014 was 710003200, and was called a module. I got it through the dealer.
    https://www.spyderlovers.com/forums/...railer+harness
    The part number may be different now but you should be able to get through your dealer.
    Oct 2017
    You are correct. The Y connector, which is referred to as a module, is part #710003200. However when going to purchase it on BRP's website, it is packaged
    with two zip ties and becomes part #219400893 @ $39.99. Go figure
    By the way, the picture BRP shows for this part is actually a picture of the Spyder full cover!?
    Gary
    1987 BMW K75s
