Results 1 to 7 of 7
    Sep 2019
    Cold Lake Alberta
    Default RT Trailer wiring harness
    Is the Spyder RTs trailer wire harness year specific? Does the harness fit all years? I have a 2015 RT special series and have a OEM hitch (coming) and will need the harness.
    Member allcd88's Avatar
    Jun 2018
    Crawford NE
    Here is the one I ordered:
    https://rover.ebay.com/rover/0/0/0?m...2F183520738273
    ....and a video I did for the installation:
    https://youtu.be/-5BK_hfWRmA
    Sep 2019
    Cold Lake Alberta
    Quote Originally Posted by splake0 View Post
    So nobody knows?
    Jun 2018
    Crawford NE
    Did you click the eBay link I posted? The wiring harness says:
    “CONTROL MODULE Trailer Wiring Harness Can Am Spyder RT, ST LIMITED 2010-2017”
    They are the same up to 2017
    Jul 2011
    Mitchell, Ontario, Canada
    The OE harness is the same for 2010 to 2017. Is different for 2018, 2019 and will not fit. The trailer harness is in 3 parts. The section that plugs into the Spyders harness is available as a separate part. So you can make any year fit.
    2018 F3 LIMITED
    Sep 2019
    Cold Lake Alberta
    Quote Originally Posted by allcd88 View Post
    I did not notice that but I think there should be another module? I want a OEM (BRP) harness with modules.
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    I just had a similar situation and here is what I discovered.
    To get the OEM wiring you need 3 pieces because BRP doesn't sell it as a complete unit.
    #1 is what I call a Y connector (BRP calls it a module harness) part # 710005823
    this connects to the Spyder wiring harness and provides a take off for the trailer
    #2 is the actual taillight converter ( BRP calls this a module) part # 710003903
    this converts the 6 wire Spyder circuit to a 4 wire trailer circuit while also isolating the trailer from the Spyder
    #3 is the trailer harness itself ( BRP also calls this a trailer harness) part #710003272
    this attaches to the output of the Module and ends in a 4 pin SQUARE receptacle that you can plug your trailer into.
    If you have anything other than a 4 pin square trailer plug you will need to either use an adapter or rewire your trailer.
    Your Spyder is a 2015, mine is a 2017 so all part numbers are the same. Hope this helps. Good luck
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
