Results 1 to 18 of 18
    Mar 2013
    Marion, Arkansas
    Default Deleting a post or reply
    For some reason I can't delete a post that I made . Is there a secrete way to do it?
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Nov 2018
    Waynesboro, PA
    You can only do an edit and change. what did you want to delete?
    My Spyder
    2012 RTL , Brown
    The "disregard" post has been taken care of.
    Mar 2013
    Marion, Arkansas
    Why can we not delete a post yourselves anymore? We used to be able too before. Just asking why it has changed.
    This discussion came up a month or so ago.
    At that time, Admin stated that was a choice that they made. Since Admin is in charge of running the site, we go with it.
    There is an edit function as CS mentioned above. You can blank out what you said through an edit. It just will not disappear from the threads. It can be deleted just by asking any one of the five mods.
    Dec 2013
    Expanding on AR's post above a bit.... basically, the 'less than appropriate' use of the delete function that users once had here on the Forum was adversely effecting the site's standing with all the search engines (standing which helps keep the place alive! ) and when the platform had to be upgraded a couple of years ago to allow this Forum to continue, that feature was something that simply HAD to go to keep the Forum viable..... so it went!
    Apart from spam & spammers, the only way for a post to be deleted now is for it to be done by the Site Admin, altho if you ask one of us Mods, we can do a 'soft delete' and effectively hide a post from public view. So, if you want to help keep the site up & working as best it can, you'll never post in anger and you'll think very carefully before hitting that 'Submit Post' button in the first place, and you'll only ever make any necessary edits to facts, spelling, or grammar within a minute or so of your initial posting. For anything other than those types of corrections pretty much straight away, please DO NOT edit your posts content to read nothing except 'disregard' or similar, (that sort of misuse is effectively what drove the need for the delete function to be removed, and misuse of the edit facility is likely to have similar consequences! )
    Rather, simply ask any Mod if we can hide it for you - you can do that via PM to any one of us if you can see that we're on the boards (green dot alongside our username in a post, or green name listed in the users on the main index page); or you could even report your own post to alert all of us immediately! In either case, please include a brief explanation as to why you want to remove it, because every post that gets deleted or edited out WILL be hurting the Forums standing & therefore viability, so we try not to do it lightly!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Oct 2013
    rome new york
    I would have to agree that is Bull. Should be able to delete your own post. Kinda a dictatorship!!
    Nov 2017
    San Francisco Bay area
    Quote Originally Posted by bmccaffrey View Post
    Well given the site is free and paid for by someone else I think your assessment is a little harsh. As Peter explained it matters how the site is rated and found on the internet. Post activity is part of what drives that, it’s not personal against the community. We want to be easy to find, as close to the top of the first page on all search engines. Does that help put it in perspective?
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    2015 RTL , Yes Pearl White
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by LeftCoast View Post
    I understand what you and Peter are saying. But, everyone has their own opinion, and doesn't have to be in lock step with the mods. When I'm searching the web, just because a link is first in line doesn't mean it's the best, most times I find it's not. Some how I don't think if the delete function was left in place (where it was originally) that spyderlovers is going to disappear. I hope that's not too harsh.
    Server Admin AnthonyG's Avatar
    Aug 2007
    mi
    Quote Originally Posted by wyliec View Post
    You would be incorrect (hopefully that isnt to harsh), when Lamont was going to close the site & i stepped in to keep it open, the site didnt show up on any search engines unless you typed in spyderlovers.
    Removal of posts that google for one has already crawled, then gets removed is a mark against the site in terms of rank & yes rank matters.
    As this site pays for itself based on advertisers & NOT user donations, the more traffic the site gets, the longer the site stays open or would you'll like the site to stay open based on user donations?
    2018 F3 , Red
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by AnthonyG View Post
    AnthonyG,
    Are you saying I'm wrong based on a search of an item I am interested in, and find the best answer is not the first link? Please explain where I'm wrong in what I had said previously. Your response did not make any sense to me. You can PM me, so we don't muddy the waters here. It's really your second sentence that I don't understand. Also, this site has been up and flourishing along time before you cut out the delete function, as you can see by the number of members.
    Aug 2007
    mi
    Incorrect part: Some how I don't think if the delete function was left in place (where it was originally) that spyderlovers is going to disappear.
    Also ill add a note: Just an fyi, your posts/threads where never deleted in the past anyways, they was merely soft deleted aka hidden from non staff members.
    2018 F3 , Red
    Dec 2008
    Syracuse, NY
    Obviously you know a lot more about what you speak, and you are speaking at level 10 while I'm at level one. I still don't understand your 2nd sentence above.
    "Removal of posts that google for one has already crawled, then gets removed is a mark against the site in terms of rank & yes rank matters."
    This is my level 1 where I'm coming from: My google search for example- why raise your heels for deadlifts? Then I review the links that come up?
    I think we are speaking apples and oranges, and that's why I can't quite understand what you are saying. In any case, you do what you feel is necessary to keep the site up. I'm not on here much anymore any way.
    Active Member BryanSD's Avatar
    Jun 2018
    South Dakota
    Another reason to not be able to delete posts so freely is that it's unfair to those that invest the time and add value via a reply to the post. Nothing bothers me more than spending 15 minutes replying to a post only to have the thread or the post itself get deleted.
    2017 Spyder RT Limited - Champagne Metallic Chrome
    - Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
    2021 Spyder RT Limited - Deep Marsala Metallic Dark
    - Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
    Jun 2018
    South Dakota
    1) Search engines bring traffic to a website.
    2) When a post get's deleted that creates a broken link.
    3) When a search engine discovers too many broken links it stops sending traffic to a site.
    4) Less traffic, less sponsors are not willing to support website with less traffic, less financial support - no website.
    Aug 2007
    mi
    Google search bots crawl a site & the many bots log said data, like this post for example.
    The post gets deleted, the link in the google search is now broken to google, which is a black mark on the site & its rank.
    The more broken links that the site has after its been crawled, the more its de-ranked unless the site keeps track of the NOW broken links in the google search console & that can be thousands if users are allowed to delete posts.
    The console will even show working links as broken seomtimes & you have to submit a recrawl telling them it isnt broke even tho they claim it is.
    If you ran a site & put up with the never ending google search algorithm that changes at least 10 million times a year, then you would understand.
    2018 F3 , Red
    Aug 2007
    mi
    Yea what bryan said too.....
    2018 F3 , Red
    Oct 2013
    rome new york
    Me neither. Get more off Facebook with many groups on there!!
