Results 1 to 12 of 12
Thread: 2019 RT help
    Jan 2020
    Leesburg fl
    Default 2019 RT help
    Yesterday I purchased a 2019 RT base. My salesman knew very little about the bike, in order to help me sync my phone he had to pull up a YouTube video on his cell phone. It was getting late and we never did get it to work. Today I downloaded a manual and read it.. It says to connect the phone to the plug in the front compartment the USB plugs in the rear are for charging only. I have looked in the front compartment and there are no plugs. There is a hole where they should be but no wires. I pulled the battery cover off and there are no wires in there. Any help would be appreciated.
    Sep 2019
    Cold Lake Alberta
    I have a 2015 and it gets connected in the rear truck. Your owners manual should be in the trunk (front trunk) unzip the liner as you did for battery access and further down there should be a manual/DVD in a plastic envelope
    Aug 2013
    SF Bay Area
    Check the videos in the Photos section on the Facebook BRP Connect User Group.
    Pushing the joystick in gets you to the basic menu. Pushing it up/down gets you to the different features and settings. In the bluetooth is where you pair the phone and headsets. Once in BRP Connect using the joystick you can navigate to the different apps.
    https://www.facebook.com/groups/2125926714370274/
    2021 F3 Ltd , Magna Red
    Apr 2019
    Clinton, MS
    Quote Originally Posted by rlreed View Post
    Yesterday I purchased a 2019 RT base. There is a hole where they should be but no wires. I pulled the battery cover off and there are no wires in there. Any help would be appreciated.
    There should be 2 holes in the frunk. An oval shaped hole on the right that should have the USB plug and a round hole on the left that should have an auxiliary 12 volt connection using spade connectors. If neither are present i would take it back to the dealer because the frunk will most likely have to come off to fish the wires into place.
    Jan 2020
    Leesburg fl
    I found the problem. When they put the battery in they pulled the wires out and left them behind the battery. All is working now.
    Idaho
    Quote Originally Posted by splake0 View Post
    Just so you know, the cluster was changed and BRP Connect introduced in 2018. When it comes to connecting a smart phone almost nothing is the same as pre-2018.
    2014 Copper RTS
    Sep 2019
    Cold Lake Alberta
    Didn’t know that.
    Aug 2013
    SF Bay Area
    One other thing. You say you purchased an RT Base? That doesn’t come with BRP Connect. Only the Ltd models have it.
    Apr 2019
    Clinton, MS
    All the 2018 and 2019 RT models have BRP Connect.
    Aug 2013
    SF Bay Area
    The new 2020’s might all come with Connect but when I bought my ‘18 the RT models I found the Ltd was the only model with BRP Connect. The S and Base models were the old way. it was only the Ltd’s that have the new dash.
    Bryant, Arkansas
    All the RT models and the F-T & LTD in 2018 came with the Digital Dash and the BRP Connect.
    The F-3 Base And The F-3s came with the old dash
    Cruzr Joe
    Jan 2020
    Leesburg fl
    My 2019 RT base has BRP connect. I just rode with the gps on, a little small but workable. I have an Samsung S9 and it paired just fine...
