Originally Posted by ARNIE R
Had a second ride on Monday and experienced the same condition for about an hour after starting off. It was very random and sporadic and could be felt occurring during a long turn, almost like an on and off switch. Then it stopped for about 4 hours. During the last hour going home, it happened once, only this time it was during a quick lane change, and I had to really turn the bars very hard.
Today, I pulled off the battery cover to check the terminal connections and discovered that I could twist the positive cable and bolt with my hand. Took everything loose, cleaned the surfaces, added di-electric grease and a lock washer and bolted everything back up. Took another 5 hour ride today and did not experience any incidents. So, hopefully, the battery connection was the culprit - fingers crossed! Thanks all for the battery suggestion.
Now, if I could just get rid of the hyper-flash issue that popped up with the new TricLed front turn signals.........
…. it was ( as stated in my post to you on 1/16/20 ) the DPS has a very large Power draw ….. and a loose connection will cause problems …… Mike
I took some heat about what style star lockwasher and where the lockwasher was placed in earlier posts. You clearly stated the wire terminal was able to be rotated on the battery post.
Placing a lockwasher under the bolt head, on a connection or joint where the joint itself has the ability to rotate, renders the lockwasher, regardless of the style less effective. As I mentioned in previous posts, there are times when the correct style lockwasher is placed between the electrical terminal AND the post it is secured to, followed by the flat washer and a second lockwasher.
Assembling in this way lessens the chance of the electrical wire moving and loosening the bolt / flat washer / lockwasher above it.
Ideally, when using lockwashers, there is no means that allows the parts to rotate loose. As an example, an exhaust manifold. In that example, multiple fasteners prevent the manifold from turning.
The downside of battery terminal is they are made of a soft material that can yield over time and use. When that occurs, the wire itself more easily rotates, and the entire connection becomes loose.
Regardless, glad to read your Spyder is fixed.
This worked on my 2016 ST-S
https://www.spyderlovers.com/forums/...led+hyperflash
Raprider (Rich)
2016 Can-Am Spyder ST-S SE5 Steel Black Metallic ( Blackbird)
BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
Kumho Ecsta AST installed on rear 4/2021
1996 Yamaha Virago 750 (Vera) - still riding
1987 Honda Shadow 500 (Shady) - sold
1982 Honda Rebel 250 (Little Reb) - sold
Call TricLed and have them send a ballast resistor or just buy one for each signal from Amazon.
Tag-Along trailer
7' x 10' Cargo trailer
Garmin 396 LM GPS
New Banshee AGM
M3 TPMS on front tires
Loose Nut Behind Handlebars
