Results 1 to 16 of 16
    Nov 2019
    dallas
    Default has anybody thought about swapping engines? from ACE 1330 to 1630cc?
    would a Rotax 1630cc fit in a Spyder F3s?
    Jun 2019
    Deltona FL
    Try it & let us know.
    I am thinking the answer is no. Sounds like an interesting project though, and possibly not for the feint of heart.
    Nov 2018
    Waynesboro, PA
    No it will not fit but, You can do anything if you really want to. Motorcycle V8.jpgMotorcycle V8.jpg
    My Spyder
    2012 RTL , Brown
    Northern Kalifornia
    Wouldn't stage 2 be easier? Only 3 screws and a plug.
    michigan
    What does stage 2 consist of ?
    Danbury Connecticut
    Quote Originally Posted by threewheel View Post
    I've always heard it said that everyone has a double..........................................
    IBA #47122
    2020 RT Limited Asphalt Grey
    Sebring, FL
    Enough $ can accomplish almost anything.
    Florida Swamp
    Unless you was bracket racing it, don't see why anyone would want to do that. You would lose most of the dependability and have to disable a lot of the computer systems. The 1330 has plenty of go for a street bike. If you want to race it, then you can build anything you want to. The more power you put in it, the less dependability you get out of it. Almost all modifications are a trade off between speed and dependability. With the extra power you will be limiting the life of the drive system, probably have difficulty hooking up on a launch, and most of the air, fuel, and exhaust systems would have be custom made, as well as the computer systems to control them. It would be a huge and costly project with no guarantee of success.
    2019 F3-S , Black & Silver
    Northern Kalifornia
    Quote Originally Posted by bluep View Post
    15+. more hp?
    Florida Swamp
    Stage whatever for the Harley was to the point that it broke the belt after just a few full power runs with 15 inch light truck tires on the rear. . The Harley could be swapped to a heavy chain drive fairly easy without fabricating any parts. Converting a Spyder to a chain drive system that will handle the additional power will probably involve a good bit of machine work and, the single tire would still be a problem for getting power to the pavement. Most likely will also need to extend the rear swing arm on back a good bit. Changing anything usually ends up having to modify 3 or 4 other things to make it work.
    Not saying it can't be done, just that it is going to bring up a lot of problems that would have to be solved even just to race it.
    As with anything of that kind, just as you finish solving all the problems and spending a small fortune to stuff the larger engine in it, the factory will announce that same engine will be an option on the new year model. Been there, done that..... with other brands.
    Dec 2019
    Western Colorado
    IMHO, if you want that big of a bore, go with the HD Tri-glide, the Milwaukee 8 will give you all that you need with its torque, especially the 124, vastly different sense of performance, and you just cant touch Harley torque, and I am an Indian fan and past rider (bambi took out my Scout on Red Mountain 2 years ago on the Million Dollar Highway, I basically walked away from a head on deer collision at 55 mph....I have been to more than one funeral where other riders were not that lucky)
    Anyway, to do that level of change is going way outside a safe or complete-able project, and if you need the displacement, just buy it to begin with. Now HD is releasing a new 131 CI too. Not to mention you need to be careful if the performance standards of the 1630 block exceed the capabilities of the Spyder frame, especailly wheel base and the span between the front tires.....
    2012 RS-S , Baja Ron Plug Wire Kit and NGK Iridium Plugs Grey and Black
    Nov 2018
    Claremore, Ok.
    15+. more hp?
    A Stage 2 is a ECU remap and a Cat-Delete and free flowing muffler. About $350.00 for the ECU flash and $225-350 for the Cat-Delete, depending upon who you buy it from, and $45-1500 for the muffler, again depending on who you buy it from. All relatively easy to do if you do the work yourself, add a few hundred $ if you have a shop do it. So, if all that only add 15 HP it might not be worth it. However, I absolutely love the way Spydie sounds with the new RLS Cat-Delete Resonator and the $45 China-Akropovic muffler.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Aug 2019
    Stoughton, WI
    If you're talking about a Wick-It ECU flash, stage 1 is $391.50 and Stage 2 is $515 .. https://wick-itperformance.com/shop-...-can-am-spyder
    2022 RT Sea To Sky
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    hey did you get to install your dynojet yet or is the weather still too rough up there?
    Aug 2019
    Stoughton, WI
    Just got 7" more snow over the weekend and down to -*'s this week. Gonna be a bit
    2022 RT Sea To Sky
