Results 1 to 10 of 10
Thread: Lew L
    Mar 2015
    forrest above Reno, Nv
    Default Lew L
    2014 Circuit Yellow RT
    Find it on Map!
    2014 RTS , Circuit Yellow
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Lew L View Post
    Find it on Map!
    Ah, THERE you are, you wascally wabbit!
    2014 RTL Platinum
    Mar 2015
    Put yourself on the map Pete.....
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    I'd add myself too, but it would just be under a few feet of snow, so you wouldn't see me anyway.....
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Mar 2015
    Hi Ray,
    But with your flashed ECM all we will see is the shadow anyways.
    Jul 2016
    Kamloops B.C.
    I have it back, haven't installed it yet. worried about the cold, and snapping plastic. Still a couple months before I think about it
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Northern Kalifornia
    Hey Lew. I'm just on the other side of the Sierra's from you tucked up close to the west side of Mt. Lassen. If I ever get close to you again I'll let you know and stop by and say Hi. We get to Tahoe and Reno at least once a year each.
    Mar 2015
    Mt Lassen is one of the trips for next summer. Been wanting to walk around Bumpass Hell for a few years. Bike problems ( water pump and suspension air leaks) curtailed some of this years trips ) Problems are all fixed now. I've learned a lot about what is under the tupperware.
    Lew L
    Northern Kalifornia
    Sad, the Dixie fire took care of about 80% of Lassen Park. With the fire a few years ago and this fire Lassen is pretty much toast. However, I read where the south entrance was open up to the summit parking lot which would give you access to Bumpass. Fortunately, Bumpass was not burned. The reason is nothing is there to burn. The newly installed walkways were left untouched. They named it Bumpass Hell because an early explorer named Bumpass fell through the crusty surface layer near the mud pots and burnt off one of his legs. So stay on the walkways for sure.
    Dec 2015
    Oakley Utah
    Done, I think.
    2014 RTL Platinum
