Results 1 to 10 of 10
Thread: Lamonster
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default Lamonster
    Hi, would you make a larger brake peddle? (The part that contacts with your foot) I have trouble finding it and my foot slips off it. The one on the F3 is a nice size.
    2019 Rally , Black
    Feb 2019
    Portland, Oregon
    Remove the pedal and move it outboard by placing the inside stud in the outside hole. If the empty hole bothers you as it did OCD me, fill it with a black bolt and nut. You can use this trick until you get one from Lamonster.
    Quote Originally Posted by Rogue Hawk View Post
    I had the same concerns as you … foot slipping off …. especially in the rain ….. I didn't make the pedal any larger ( it wouldn't fit my floorboard ) so I used a smallish rectangle of galv. sheet metal and dimpled it with a large nail, ( now looks like a cheese grater )…. then I wrapped it around my brake pedal PAD which allowed me to re-mount it using the OEM bolts …. my foot has never slipped again …… Mike
    May 2013
    Apex, N.C.
    Web boards used to make one. I picked up one when I got the boards for my RT, but transferred the brake pedal over to my F3T.
    Active Member SPYMAN's Avatar
    Nov 2007
    Nixa, Missouri 65714
    PE #2735
    RUBBER SIDE DOWN SHINY SIDE UP!!!!!!!!!!
    Never ride faster than your Angel can fly...
    Nov 2007
    PE #2735
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by SPYMAN View Post
    Nice! I'm putting that on my wish list.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    This is the Ryker forum though. That won't fit the Rykers.
    Apr 2015
    Chicago
    That would be great if he made it to fit the Ryker. Not sure if he will see my post.
    2019 Rally , Black
    Lamonster posted a thread on new Ryker stuff. Check it out.
    https://www.spyderlovers.com/forums/...for-your-Ryker
