Results 1 to 12 of 12
    SF Bay Area
    Default Parts List Question
    Stupid question.......again
    This concerns my 2014 RTS SE6.
    In the past when I needed to identify parts for a particular issue, I used Cheap Cycle Parts. They have diagrams for different areas of the bike which you can zoom in on and get part numbers. Very handy, at least for me.
    Unfortunately, they don't have every area or part needed. For example, I needed to add a second shock to my trunk after adding a luggage rack. As usual, the forums provided the info I needed! Thank you!!!!
    Question is, how do you identify parts for different applications, besides bothering you guys all the time? Now, I'm looking for the screws that hold the inner trunk cover to the outer cover.
    Thanks in advance!
    2014 RT-SE6
    Akrapovic Sport Touring 3C Silencer
    High Mount Third Brake Light
    Kuryakyn Black ISO Motorcycle Grips
    LaMonster Spyderdock
    LED’s everywhere!
    Russell Day-Long w/ Backrest
    Seal Floorboards
    Spyderpops Bump Skid
    Spyderpops KOTT Grill (Keep Out The Trash)
    Squared Away Alignment
    Riding taught me why dogs stick their heads out the window!
    Northern Kalifornia
    If you don't have any, try finding a matching screw from another location on your spyder and the take it to Ace Hardware and match it up. That's where I bought all the parts to build my own magic mirrors. They have a huge selection and inventory of metric and SAE nuts, bolts, screws and all types of fasteners.
    INDIANA, USA
    Default Nuts & Bolts
    .... ....Ace is the Place. Give them a try.....
    ENJOY YOUR LIFE WITH A SPYDER
    SoFlo
    For parts research, the actual Can Am parts catalog is best. Believe the home page here has a link to it. This should be the place, hope it helps.
    https://can-am.brp.com/on-road/shop/...ts-iframe.html
    SF Bay Area
    Quote Originally Posted by Little Blue View Post
    Yep. I'm an Ace fan for sure. I already did that and I have a working replacement. However, being a little anal retentive, I'd like stock parts. The new screw works but it is a phillips head. No big deal, but if possible I'd like to keep all the fasteners stock.
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Feb 2012
    Spring City,Utah
    I think this is the part you are looking for. It is part number 17 on the diagram and Can Am part # 250000720 which is a superseded number for the original number.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2019
    Portland, Oregon
    Gas struts (you called it a shock) are a stock, off-the-shelf item at auto supply stores. BRP does not make their own, they buy from a supplier, just like you can.
    If you haven't purchased one yet, take yours into an auto supply and they'll match it. Chances are excellent the new one will be stronger and you won't need a second one.
    Northern Kalifornia
    Be careful and don't get too stiff of a strut because you may over stress your hinges or your mounting points.
    Jan 2019
    Hunter Valley NSW Australia
    2017 RTL , White
    Sep 2018
    Sneedville, TN
    2018 Spyder RT Limited
    Asphalt Gray
    Can Am Passenger Armrests
    Can Am Comfort Seat
    Spyder Accessories Floating Footpegs
    Utopia Driver Backrest
    Bajaron Sway Bar
    Sena 20s Bluetooth
    Lidlocks Helmet Holders
    F4 Tall and Wide Tinted Windshield
    Fobo Tire Monitor
    Lamonster Spyderdock Cell Phone Holder
    Sheepskin Seat Cover
    Drink2Go Cup Holders
    Magic Mirror
    Can Am Trailer Hitch
    Missing Belt Guard
    Wish List - LED Headlights and Fog lights
    USA
    I like the Cheap Cycle Parts diagrams because at least for me the diagrams size and position can all be controlled with the mouse. Much easier to navigate than the BRP website. Left click grabs the diagram to reposition, scroll wheel resizes.
    h0gr1der
