Results 1 to 13 of 13
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    Default Time to crawl under the Spyder
    After a ride today - I decided it was time to crawl under the Spyder and see if I could find out what might be going wrong with this rear suspension and look what I found! Would this be the cause of my air bag not holding air?IMG_1385.jpg
    Also - where can I find an electronic copy of the service manual for a 2019 RT Limited?
    Thanks,
    2019 RTL Asphalt Gray
    2019 RT Limited , Asphalt Grey
    Nov 2012
    North Las Vegas, NV
    Yes, that will also keep the compressor from working. https://www.google.com/search?client...n+am+spyder+rt
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2018
    Waynesboro, PA
    Try e-bay
    My Spyder
    2012 RTL , Brown
    Feb 2019
    Portland, Oregon
    I got a paper one off of eBay for $65 -- don't buy that one, it came with no table of contents or index. I have to add dividers with labels to make searches easier. I am a paper manual guy. Some have said they paid less for better. Live and learn.
    Sep 2012
    Stetson, Maine
    Looks like the arm for the ACS switch. I do not have the manual handy. There is a right way of hooking that arm correctly. Hopefully some one can post a picture.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Apr 2019
    Clinton, MS
    Would this be what you are looking for?
    SoFlo
    Get a bolt that fits the rivnut, install it and enjoy. Pretty sure it is a 6mm diameter. Guessing length is about 15mm.
    On the swingarm end, it only goes one way for proper fitment.
    Nov 2019
    SE Pennsylvania
    Thanks PMK - that was going to be my next question - what size bolt? I'm surprised that the service manual doesn't give this info. It looks like from the picture - it is just a bolt - no nut?
    Thanks
    SoFlo
    Quote Originally Posted by Snakeyes View Post
    Thanks
    On the bottom, no true nut. The nut is a rivnut, secured into the swingarm bracket. Please understand, I am guessing at the bolt specifics.
    Nov 2015
    Chardon, OH
    And as you can see, the tab that the rivnut is expanded into is not very thick. So, don’t be surprised if it starts to turn as the bolt starts to tighten. Just grab that portion of the rivnut that is behind the tab with pliers or another tool of your choice in order to keep it from turning as you tighten the bolt.
    Doug
    ”Freedom is not a loophole”
    Nov 2019
    SE Pennsylvania
    Went out and bought a M6-1.0 x 20 mm (could have even used one size longer) bolt and fastened everything down and went for a ride. What a difference!!! My rear suspension is now doing it's job.
    Thanks for all the help! Also - I purchased my service manual online this morning - so I'm ready for the next adventure
    Feb 2012
    Spring City,Utah
    Thanks for letting us know the resolution. Happy ryding.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2019
    Cimarron ks
    Got a cd on ebay for a2011 for 15$ with freight its awsome had many more years listed
