Results 1 to 12 of 12
    Dec 2015
    Louisville Kentucky
    Worked out
    Sep 2012
    Stetson, Maine
    First I would check your air pressure, check at the valve under your seat. If it is below 20 lbs. I would add air, Put in around 60 lbs. check pressure 12 hours later and see if pressure dropped alot, more than 10 lbs. If it has tban you have a leak. I would guess it would be your check valve/one way valve. This is connected to your compressor. It is probably gummed up. Not real easy to get at for some one not mechanicly savy. Another possiblity is your ACS switch which is located on the left side by your swing arm. I went thru 2 of those.
    If your air bag holds air pressure after 12 hours, it is probably your air compressor. It is possible that you have a pin hole in air bag. It is not that difficult to convert you air ride to manual. Once you find the cause let us know and we can give you more ideas. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Member allcd88's Avatar
    Jun 2018
    Crawford NE
    Mine did the same. The compressor for the ACS went bad due to a leaky check valve. We were on a twelve day trip when I noticed the pump running way too often. A few days later the pump went bad. Luckily the leak wasn’t real bad and I just filled the air shock every time I stopped to fuel up. Check the fuse as well. If I remember right, the horn and fog lights are on the same circuit as the ACS pump.
    Dec 2015
    Louisville Kentucky
    Well, I checked the air, it was full
    Feb 2015
    Carson City, NV
    Not real sure on your model, but I think the bike has to be running and in gear for all that to work.
    Bob, k7xi. 2013 RTL
    Durham,Maine
    Quote Originally Posted by k7xi View Post
    The bike has to be running and in gear, before the system starts to work!!!
    2012 RTL , Pearl
    Dec 2015
    Louisville Kentucky
    2015 RTS just had the oil changed,
    Dec 2015
    Louisville Kentucky
    worked out
    Sep 2012
    Stetson, Maine
    There is an aftermaret compressor that will work. It is alittle larger. It is around $90.00. I was going to get one but decided to go manual instead. If you are going to ryde your Spyder awhile before they can replace compressor, I would suggest disco necting (power) the bleed off valve. Valve is mounted to frame above muffler. This way your Spyder wont bleed off air. Bruce
    New to Sue and I
    Faribault, MN
    Many of us have converted the adjustable systems to only manual. I took out the compressor, check valve and ran hose direct from schrader valve under seat direct to the airbag. Holds air fine, can set it and forget it.
    Past Threads at https://www.spyderlovers.com/forums/...020-Compressor
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Dec 2015
    Louisville Kentucky
    worked out
    Active Member LJspydee's Avatar
    Nov 2012
    Casa GrandeAZ/formally WaterlooIA
    Did you have to do anything besides remove the compressor, check valve and run the direct line? Any fuses or anything to do with the position sensor?
    2013 Silverado 2500HD Duramax
    2017 Honda Pilot
    2018 Maverick Trail 1000 DPS
    2015 RTS SE6 Intense Red Pearl
    2014 35' Keystone Fuzion Impact Toyhauler
    Ultimate Seats passenger backrest, Adjustable wind deflectors, Minitrailer USA trailer, Can Am driver backrest, Corbin passenger armrests, after market hitch, DIY bump skid, LED turn indicaters, cup holders, frunk decal stripes, DIY GPS mount, DIY Gopro dash mount, aux 12v & USB outlets, DIY belt rock shield, BajaRon swaybar, frunk 12v outlet
