Results 1 to 20 of 20
    Member johnc1921's Avatar
    Jul 2019
    Phoenix, AZ
    Default Oil Drain Plug Overtightened
    I'm doing my first oil change on my 2013 Spyder RT. Stupid torque wrench clicks so fast I'm never sure if it's set right or just messing with me. That said I'm pretty sure I cranked it too tight. I've ordered another set of drain plug washers. Should I pull the plugs out and re-tighten them? Or wait until the next oil change?
    2013 RT , Copper
    SoFlo
    If it were me, and you truly believe your torque wrench applied inaccurate torque, I would remove those drain plugs and replace the drain plugs. Would also purchase a known high quality torque wrench.
    The drain plugs will tend to become more locked in place with use. With so many reports of failed drain plugs, including oem, why risk a huge expense at the next oil change.
    Not going to debate torque wrench quality or calibration, merely if I question the actual function of it indicating the torque point, I use a vice and check the operation. I have thrown away a few torque wrenches over the years. Simply not worth the risk.
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    The torque on oil drain plugs is so low- in the Inch pound range that using the book values calls for very careful application of a 1/4" drive torque wrench that can operate efficiently in a mid-range of its operating span. Also, I question the published torque values as are they a dry value versus a "lubed" value as all drains will be wet and low friction which is reduced by about 25%.
    I try to use a 6" ratchet or less and only snug the plug tight--- having a 12 inch lever arm of the torque wrench seems a bit risky to me.. JMHOIMG_0645[1].jpg
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Nov 2012
    North Las Vegas, NV
    Torque is tricky on drain plugs because they usually have some oil on the threads. Most torque specs are for dry threads. As long as you have no leaks wait until your next oil change.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    SoFlo
    The infamous wet torquing to a dry torque spec with a questionable torque wrench is never good...
    Plus the engine cases are aluminum, always an adventure.
    Houston
    Using a bonded rubber and steel sealing washer instead of the old fashioned crush washer pretty much negates the whole torque issue. Just put the plug in and about a 1/4 turn snug. Its seals and does not easily streach fragile aluminum threads. We have shifted to using these bonded rubber and steel sealing washers in all oil changes as we now get zero leaks first try every time.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    SoFlo
    Agree. Not stealing your thunder, I snag a few at a time, been installing them for a long while now.
    Had some ideas to offer them to owners here, simply did not. Likely Baja Ron will soon stock them if he doesn’t already.
    Jul 2019
    Phoenix, AZ
    Great advice! No leaks from the drain plugs so far. I had a minor seep on the oil filter. A slight tightening of the screws seems to have stopped it.
    The torque wrench is from Harbor Freight, so not high end. The long handle messes me up with the low torque values. I'll run some tests on it.
    The bonded rubber sounds like a better option. Anyone have a good source and specs?
    2013 RT , Copper
    Mar 2008
    Hesston, PA
    I also went to the bonded/steel style washers per jcthrone recommendation...Just tighten them snugly without torquing...Changing all the toys in the toy box over as the oil changes come due...Bought a large assortment...
    Quote Originally Posted by larryd View Post
    Someone else here just posted that He got a few on Amazon and posted a LINK ….. look for a similar post to find it ….. Mike
    Quote Originally Posted by johnc1921 View Post
    As others have said …. I wouldn't try to Torque them ….. just tighten with a Ratchet till they are snug … if it drips just tighten a bit more …. I learned a long time ago to ALWAYS set the Ratchet … BEFORE you use it …. that way there is no confusion about what it will do ….. I'm fairly certain neither plug is damaged , the reason they are difficult to remove is the threads get a Varnish coating from heat / cool cycling …. To break that loose, put the socket on and give a sharp Tap ( with a hammer ) to it, this will break the seal...… this has worked for me dozens of times … good luck .… Mike
    Clinton, MS
    Would you happen to know the size of the bonded washer, seems several are available.
    Also, why is the oil drain plug built like it is with the multiple offset o'rings?
    If it were me. And I was in doubt. I would simply loosen the drain plug a bit and re-tighten. You won't lose any oil this way and you will get it done before the heat cycles make your drain plugs even tighter.
    I never use a torque wrench on a drain plug. Just too many things can go wrong. Most people, including dealership techs, get these too tight. They just need to be hand snugged with 3/8" drive wrench.
    I wouldn't worry about the washer being damaged. They are pretty tough. I did 4 oil changes using the same washers (and 1 with no washer at all!) with no leaks or even a film around the plug.
    Houston
    12 and 16 would be correct for a 1330 engine. 12 and 14 for a 998. On the 1330 engine, the engine side oil drain plug has multiple o rings as it drains the sump and the crankcase at the same time.
    Jul 2010
    Las Vegas, NV
    Concur. The sealing washers are great; buy some, and next oil change, install them.
    Joe Meyer
    Clinton, MS
    Thank you sir. Thought that might be the reason but was not sure.
    May 2019
    Carlton
    Leave em until your next oil change then swap them out.
    Jul 2018
    Saskatchewan
    SoFlo
    Quote Originally Posted by Geep View Post
    One type of many possibilities.
    For whatever reason, Rotax uses a tapered seat area on the drain plug. Not saying that is good nor bad.
    Merely, anyone looking to use sealing washers needs to verify dimensionally they will seal correctly. This means the sealing material does not enter the threaded bore, nor extends beyond the fasteners edge. Essentially, the sealing surface should fully accept the complete contact surface of the sealing gasket.
    Ideally, you should get the correct material and temp range. Aluminum is ideal to minimize corrosion, but not mandatory.
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Sounds like the 60 year old trick of a piece of shoe leather or belt will do the trick just fine. No leaks & easy to get loose.
    Can Am 2013 RTL SE5
Tags for this Thread
