Codes P228 and P011C
Hello, I just finished changing the coolant fluid as part of my winter maintenance and I now have these 2 maintenance codes P228 and P011C along with a check engine light. I have the frunk removed at this point and was wondering if that might be related to my problem?
Not sure if these are correct, but here goes:
From the generic database: P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P011C module:ECM
Ambient Air Temperature Sensor circuit high.
Sensor disconnected
Defective sensor/ damaged wires/ wire shorted to battery Vbat/ ECM voltage supply too High.
Make sure sensor connector is fully inserted.
Measure voltage between harness connector pins 1 & 4 .
(expected value: 4.8 to 5.1 volts)
Measure resistance from connector: ECMA-H4 to AAPTS-1
(expected value: < 2 Ω) Measure resistance from connector: ECMA-J4 to AAPTS-2
2020 RTL SE6 Asphalt Grey
2014 RT SE6, Pearl White 57k (2014-2020)
2008 GS Premier 17k (2012-2014)
They are related to your trunk removal. You unpulled the sensor on the right side of the trunk. Should return to normal after reinstalled.
Code P228 is not a correct code
....and we're gonna ride, we're gonna ride.....
ride like the one-eyed Jack of Diamonds, with
the devil close behind,.....we're gonna ride....
2008 GS.....PE # 2888
