Trailer hitch
Do you think my hitch from my 2015 RTS will fit on the new 2020 Limited?
You won't be able to make even a WAG until BRP publishes a PN for the swing arm, among other parts. The part diagrams look the same for both MYs but there's no way to tell just yet.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
According to the BRP accessories catalog, the trailer hitches have a different part number. So my guess would be, no, they are not the same.
You cannot go just by that as the hitch maybe the same, but the wire harness would not be. Since the hitch that BRP sells comes with the wire harness there would be a different part number.
An example of this is I installed the hitch from our 2014 RT onto the 2018 F3l, but I did need to purchase the different wiring harness from BRP.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
And if BRP does the same thing as they did in '16 with the F3L, you won't be able to buy just the wiring harness for at least a year or more.
I will make a guess it will fit. But I cannot be sure. The pre 2018 trailer harness will not plug into the main harness. But it should if you buy the control module harness service kit. Part number 219400853.
2018 F3 LIMITED
