What has everyone added to their RT?
What has everyone added to their RT. See my list in my signature.
2020 Can Am Spyder RT Limited "The Comet #2"
Baja Ron Sway Bar
Passenger Armrests From Can Am
Wolo Big Bad Max Airhorn
Lamonster Top Cuff W/Ram Ball
Lamonster Power Plate
Tackform Phone Mount
Key Cover from Ebay
Lamonster Mirror Locks
Ultragard Cover from Lamonster
Top Grills from Spyderpops
Garage Door Opener from Spyderpops
3.5mm Extension from Amazon
Lamonster USB Cable Holder & Cable
Foam Grips from Spyderpops
Tricled Strobe Brake Light module
Tricled Bag Lights (replace reflectors)
Tricled Turn/Brake/Run Signals Rear
Tricled Floorboard Lights
Tricled Sequential Run/Turn Fender Lights
Tricled A-Frame Run/Turn Lights
Tricled LED American Flag Mount & Flag
Showchrome American Flag
I added a sway bar on my RT.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Deanna
I forgot about my swaybar! I added one too. Worked great. I also modded the trunk and ran an 3.5mm cable from the back of the byke to the front for tunes/phone hookup.
Baja Ron Sway Bar
Key Cover from Ebay
Laser Alignment. GO NETZLEY!
Aluminum Billet Windshield Arm. Thanks noboot !
BajaRon Bar and Links
BRP (Sena) Bluetooth Communication System
Sena 20s Headsets
Zumo 590 LM
Spyderpops Bump Skid.
TricLED Bumpskid LED light kit smoked tube
Spyder Lyter fender lights both amber and red mudflap.
WOLO Bad Boy air horn.
Hex Head drain plugs from Dimple Products.
OEM Backrest with a purse I salvaged from Utopia
Custom Dynamics Red Brightsides replacing side cargo reflectors
Custom Dynamics High Mount Light wired as running and brake light.
Lamonster LED Headlights and Foglights.
Sports Imports LTD LED arrows on the mirrors
TricLED Wide View Mirrors
Show Chrome black rack with stand-offs.
Kumho Solus KH16 Front Tires 175/55/15
Cooper Mastercraft LSR Grand Touring rear 215/60/15
Having said all of the above, I'm buying the 2020 RT Limited and planning to keep it mostly stock.
I'm getting some OEM accessories: Additional front lights, rear trunk rack, the ZUMO 590 mount, and driver backrest.
I'm also moving the car tires onto the new bike.
IBA #47122
2020 RT Limited Asphalt Grey
We have a 2018 RT Limited
> RAM balls on a Lamonster Garage Spyder cuff and DIY handlebar bolt mount for GPS, phone mount, cup holder, etc.
Pics here, in post #4 https://www.spyderlovers.com/forums/...15#post1442415
>Direct to battery (bypass Canbus and Nanny) 6 connection Power block - powers cigarette style power port on Spyder Cuff, 2 12v coax outlets for heated gear and dual USB rocker switch style outlet
https://www.spyderlovers.com/forums/...37#post1402237
>Diamond Custom seat (had them on the last 3 bikes) that I modified the passenger backrest to better fit the Admiral (I am the Captain and have authority when underway, but the Admiral tells the Captain where to go)
Pics, scroll to post #8 - https://www.spyderlovers.com/forums/...72#post1469372
>Spyderpops LED bumpskid with remote control to change pattern of lights. (Daytime set to cycle from 25% to 100% brightness like the modulating headlights on bikes, steady on 25% at night)
Video, scroll to post 31 - https://www.spyderlovers.com/forums/...95#post1435695
>Spyderflap.com rear mudflap. I really does help keep the back end and passenger drier when the roads are wet.
https://www.spyderlovers.com/forums/...d-and-thougnts
>Swtitched rear trunk light powered by 2 9v batteries - used the "Try It Now" circuit from the packaging and a rocker switch to turn it on
>Pinstriping by "Chicken Scratchin' by Lynus" at the New Hampton Motorcycle Rally, formerly the Davis Rally https://www.spyderlovers.com/forums/...=1#post1474411
Chicken Scratchin' - https://www.chickenscratchin.com/
>We had a license plate frame made with the name of the trike printed on it. It can be seen in the pictures of the Spyderflap above.
>I have a few different throttle assists - On the RTL I like one that was given to me years ago. Its a wooden spoon that can be swung out of the way when not in use or adjusted to suit. https://www.spyderlovers.com/forums/...=1#post1482108
>Longer brake pedal - The OEM pedal is too short, but the aftermarket one is a bit too long. Somewhere I saw a post about cutting the aftermarket pedal down to give a bit more foot room while making it easier to find the brake.
Planned - Belt idler pulley/tensioner, Spyderpops rear LED light kit, Magic Mirrors, Baja Ron sway bar, passenger armrests (most likely Diamond R)
<> Got a set of Lamonster Garage No Bad Vibes (NBV) highway brackets. I have a set of Kuryakyn Dually Iso Pegs to go onto the brackets.
2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
I may be wrong, but I don't see a signature?
h0gr1der
2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
States Visited on Less than 4 wheels.
He has been "Grayed" out. Not sure what that means?????
We have a 2018 RTL Blue+/Chrome+ & loving it:
Tri Axis Handlebar. Adj Drivers Backrest, Adj Chrome Side Wind Deflectors, BRP Armrests, Black Travel Cover, Drink holder mount, Super Clamps, Spyder Key Holder BLUE, NBV Highway Bars w/Kuryakyn Widow Pegs, Bat jump port, Fuze Block FZ-1 w/Wire Kit, Lrg Brake Pedal (cut 1/3 off), Spyder Cuff w/Holder, HCTL, HCSL, HCFL Nets, Rugged Geek, Magic Mirrors, Push Pin Kit, USB Cable Holder, USB Type C. 1" Ball Mount. Dash Mount, 12v+Dual USB. Console 4.2A Dual USB w V mtr, Longhorn Mirror Lt Kit, KOTT Grilles, Missing Belt Gard, Next gen Bumpskid & remote, Double daytime A-arm LED lights, Foam Grips, Oxford Blue Dashboard & Rear Bumper, FOBO 2 Trike + Air Bag, Chrome trim #102 103 104 106 303 & 304, SPY184 & SPY250 rear light & high mount brake/run/turn w/ strobe feature, Blind Spot Mirrors, Top Case mirror, FH400 Flag Holders, RYDER 3-PIECE logo kit, SPY160 LED Saddle Bag Light, Phone Phang Holder, BRP Hitch Kit, Trailer Splash Plate, 2015 Freedom Trailer with LED brake-run-turn Bumpskid.
Reason: Added more farkles.
Originally Posted by blueknight911
81!!! Wow!
Baja Ron Sway Bar
Key Cover from Ebay
I think that usually means the member has been banned. In this case it must have been short lived because I see he is online now, 12/21/19 10:45 PM MST.
2014 Copper RTS
It's in my signature. By far my favorite modification is the small windshield with the X-Screen. The ability to control the wind can keep me warm when I need it, or, as is more often the case, really let me feel the wind on a hot summer day.
2020 RT Limited in the ultra cool Deep Marsala Dark edition.
Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
Maintained by Lou at Pirate Powersports.
Luckily my wife is in agreement with the Spyder, otherwise I may have been murdered for all the mods long ago.
After reading the Blueknight has over 80 mods, I decided, since I never actually counted how many we have, I itemized and number the list. He still has way more mods than us.
2014 RTS,
1) Yokohama s.Drive rear tire
2) Federal Formosa front tires
3) F4 tinted windscreen
4) Fox front shocks
5) Bajaron swaybar
6) Rivco mirrors
7) Can Am adjustable side vents
8) Corbin seat
9) Corbin driver backrest
10) Corbin passenger backrest
11) Corbin passenger armrests
12) Dual antennas
13) Sena Bluetooth Dongle
14) Finless Bobs dongle harness
15) Sena 20 headsets
16) Garmin 660 system
17) JBL speakers
18) JT machine shop accessory mount
19) Parking brake beeper silencer
20) Gorilla alarm
21) NoBoot billet windscreen arm
22) BRP accessory rear trunk lights
23) Custom IPod / Dongle trunk mount
24) Stainless Steel air ride valve
25) Left and Right bodypanel Camloc 1/4 turn security fasteners
26) ND / Nippon Denso spark plugs
27) Dimple brand or Gold Plug brand oil drain plugs, have both so depends on my mood which get installed
28) No leak drain plug seals
29) K&N airfilter
30) Modified engine air intake duct
31) Trimmed exhaust stingers
32) Lamonster bypass pipe
33) EBC brake pads on all corners
34) Pentisone brake fluid
35) Cyclops LED foglights
36) BRP / Can Am HID headlights
37) Fuel gage and temp gage drains
38) Aircraft sound proofing on acoustic panels
39) Butler driver drink holder with insulated cup
40) Passengers drink holder by Profile
41) BRP trailer hitch
42) BRP Trailer hitch wiring kit
43) Aftermarket trailer wiring connectors
44) DESS upgrades
45) Custom rear tire mudflap / water spray deflector
46) TSB belt tension
47) Correctly aligned front wheels
48) Dynamically balanced front wheels
49) Ride on in rear tire
50) RT622 trailer
51) RT622 wheels that match style and color of Spyder front wheels
52) RT622 upgraded hatch seals
53) RT622 hubs have Bearing Buddies
54) RT622 color matched hitch
55) Stant vented fuel cap
56) Fuse swapped to always powered rear powerport / used to connect Battery Minder
57) Cool stickers inside frunk lid
58) RT622 modified for and has small motorcycle tag.
59) Cadillac Escalade horns
60) Hopnel sidebag mesh bungies
61) BRP trunk lid mirror and makeup case
2012 RTL
BajaRon Sway Bar (site sponsor)
Led Headlights TricLed
Led Driving lights TricLed
Sena Bluetooth Thanks motorcycle Dave (site sponsor)
Gel seat pad motorcycle Dave (site sponsor)
Utopia Backrest
CanAm Spyder Accessories hitch and wiring
Movable wind wings
Value Accessories trunk rack (site sponsor)
Hopnel rack bag Brown
Hopnel tool bag for trunk
DIY handlebar ram mounts (2 with 2 balls each)
foam grips
led fender stripes TricLed
DIY gas door in seat
magic mirrors
car tires all 3 wheels
pinstriping Shane Syx at Rat Fink Reunion
nose art Jeff Dastrup @Red Rock Spyder Rally 2017
Cup Holder Diamond R
Flag Holders dual Rivco
hex head drain plugs Value Accessories
JT's air cleaner mod
Better plug wires BajaRon (site sponsor)
EBC disks and pads BajaRon (site sponsor)
Seal Floorboards (no longer made)
stronger seat support strut
battery tender wiring
Rt lower vent block off plate(Spyder Doc)
chrome edging on saddle bags.
Hannigan Europa I trailer.
Chrome fender markers Value Accessories (site sponsor)
orange colored calipers
orange rear wheel
Black Decal on windshield (Wrap My Spyder site sponsor)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
2014 RTS,
4) Fox front shocks
5) Bajaron swaybar
6) Rivco mirrors
8) Corbin seat
12) Dual antennas
17) JBL speakers
20) Gorilla alarm
29) K&N airfilter
44) DESS upgrades
50) RT622 trailer
I think #59, might be one of the most interesting adds yet. Was it hard to hook up?
Baja Ron Sway Bar
Key Cover from Ebay
Originally Posted by pegasus1300
2012 RTL
Utopia Backrest
Movable wind wings
foam grips
magic mirrors
Flag Holders dual
orange rear wheel
I bought 69 Mustang Grabber Blue paint from G2, that I plan on spraying the calipers with this spring. Can you see it really well through the wheels?
Baja Ron Sway Bar
Key Cover from Ebay
I added the sway bar in Sept of this year.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Not difficult at all.
20180609_201116.jpg It will show fine. As you can see I did mine in orange.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
My list is pretty sparse compared to many here, and looking at some I could see them used as a shopping list
- Magic Mirrors
- Nankang Rear Tyre
- Baja Designs S2 Pro driving lights with mixed lenses
- Wilbers 640 Rear Shock with remote adjuster
- Wilbers 630 front shocks
- 8 Channel Solid State Relay supplying Tow hitch, driving lights.
- Airhawk R seat for me.
- Sykik TPMS sensors
and on the 7th Jan
Reason: typo
